Unusual starting problem - please help!
SkydiveMacca
Car is a 1994, GZ TT, J spec that i've owned for a few months now and it hasn't missed a beat.
This morning, I turned the key, nothing. Turned it again and it fired without issue. Guessed it must have the immob kicking in. Later in the morning, went to go out again and the following happened:
Turned the key, heard the fuel pump, turned all the way round and nothing. Not like a flat battery nothing as the radio, lights and and fans were are still fine. Turned all the electrics off, and tried again. Fuel pump noise, and again, nothing. No clicking, no turning over, no firing, nothing. Turned it all off, tried again and it fired as normal first time.
Drove out for lunch, parked, turned the engine off, and tried it immediately to see if it would start. Fired first time, no issue. Tried again, fired no problem.
Came back to the car about 2 hours later, and back to the same problem. Took about 10 attempts, but eventually it fired.
What's odd, is it's not like it's a dead battery and i'm getting clicks, and it's not the immob as the light is off, there's just nothing, but then when it fires, it's absolutely like it normally would start.
There's no issue at all while driving, so don't think it's a filter, or plugs etc as once started, everything seems to work as it should.
I've had a look under the bonnet, and I can't see anything that looks out of place. Battery connections are firm and intact.
Anyone got any suggestions? Car is my daily, so really need to get it fixed!
Have been having a play, and obviously it started first time every time. I had a look at both fuses boxes and things seemed to be seated ok and not blown, however, I noticed this and am concerned by the top fuse. I think it's the alternator one, but doesn't look in good condition?
Also, what's the red + bolt for to the right of it?
Still having problems and need to get it sorted by the weekend as am meant to be going away :(
Are there any safety type features that might be stopping the engine firing? Sensors that might provide some kind of cut out?
If the starter contacts were duff, would you hear clicking while it tried to do something?
Currently, when you turn the key to position one, everything electrical turns on, including the fuel pump. Turn the key further and I either get absolutely no noise, or one slight crank noise, then nothing.
Eventually, when it does crank, it hits first time, like nothing was wrong?
Could it be the contacts, or the whole starter?
Guest 2JZ GE W58
Starter contacts?
good call, i had this prob too was just getting a click when turned key instead of cranking. the starter contacts were burned out from previous owner dogging it on bad batteries i would say. stuck in the starter off me spare car and alls well since
