james_cbr Posted November 2, 2013 Share Posted November 2, 2013 Hi all doing na - tt conversion with tt6 ecu Dose the speedo feed go right from gearbox to dash or dose it go via the ecu Wondering if fitting the tt6 ecu would change the speedo Running a01b non lsd dif want to fit an lsd at some point would the lsd dif then fix the speedo if it was alterd by the tt6 ecu ? Quote Link to comment Share on other sites More sharing options...
