Where to get new camber adjustment bolts?
marc_p
Hi Guy's,
Got a feeling the answer to this might be to go to Mr T, but thought I would ask. I'm currently polybushing the car and the bolt was seized solid in the drivers side inner rear control arm bush, which resulted in me having to take the subframe brace out to give me full whacking ability on the bolt, the bolt did come out eventually, but I will not be re-using this bolt, so ideally I'd like to get new bolts for all the lower arm bushes, but do I have to go to Toyota for these? Also, I know there is a slight difference on the lower arms between pre and post facelift(mines facelift), is this bolt the same across both variations or is there a difference?
Thanks
Marc
Hi Guy's,
Thanks
Marc
I bought mine from Toyota, they're not too expensive and if you only want one i'd buy genuine
rather than unknown
I am glad this thread has popped up because the exactly same thing happened to me but on the rear driver side and the garage simply replaced with one they bought from a hardware store and it concerns me, hopefully somebody will explain further.
Dunk, don't suppose you still have the part numbers lying about?
Was going to order the below for replacing front and rear at both sides:
-48194C x2
-48198C x2
Then for nuts/washers:
48194D x2
48198D x2
90201-16017(2) x2
48068G x2
48069C x2
This was taken from the below link:
http://www.villagetoyotaparts.com/showAssembly.aspx?ukey_assembly=332238&ukey_make=1021&ukey_model=14428
They have eccentric washers on them and doubt very much a hardware store would have these.
I'd get it checked and go find another garage
I can't find a supra one but they're pretty much like the one below
I am not using them anymore the mechanic that did this also cut the rear polypro bushings which I have recently received new ones I made them buy me.
-48194C x2
-48198C x2
48194D x2
48198D x2
90201-16017(2) x2
48068G x2
48069C x2
No sorry Marc i don't, when i replaced all mine i got the lot off Steve Manley
