Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 I currently own a jap spec twin turbo 6 speed manual and I`m looking to go down the single route. I`m just after some advice as to what supporting mods are best and what turbo set ups have been tried and tested as there are some of you guys on here that know a damn site more than I do any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 30, 2013 Share Posted October 30, 2013 Using the search function is your best bet. Been covered hundreds of times before. Do a LOT of research and then fill ya boots Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 30, 2013 Share Posted October 30, 2013 Start defining your power goals and budget. This will guide you straight in the right direction. Quote Link to comment Share on other sites More sharing options...
Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 Between 500-600bhp 2k-3k Maybe more if needed Quote Link to comment Share on other sites More sharing options...
James Posted October 30, 2013 Share Posted October 30, 2013 You could do a single conversion for £5-6k if you shop around A LOT and gather all your parts second hand and carry out all of the labour yourself. Even then, there will be a bunch of little parts that will make that figure rise and rise still. Generally, budgeting for at least £10k+ is to be expected for a single build. Usually nearer £15k. Then add on to that as things go no doubt. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 30, 2013 Share Posted October 30, 2013 Not a chance on that budget. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted October 30, 2013 Share Posted October 30, 2013 Not a chance on that budget. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 30, 2013 Share Posted October 30, 2013 Not a chance on that budget. +1 Quote Link to comment Share on other sites More sharing options...
Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 Thats not my budget was just a rough figure of what i was thinking.. so no drama ill make it happen either way Quote Link to comment Share on other sites More sharing options...
marc_p Posted October 30, 2013 Share Posted October 30, 2013 Thats not my budget was just a rough figure of what i was thinking.. so no drama ill make it happen either way I'd budget £10k but be prepared to go over that. Mines run me at about £12k or more and that's with me doing all the work myself. Quote Link to comment Share on other sites More sharing options...
Big Supes Posted October 30, 2013 Share Posted October 30, 2013 I'm tempted to keep my eyes peeled for a cheap single turbo (seen a few going for around 7k) and break it. You'll get all the bits you need and claw back a bit of cash on other bits. Quote Link to comment Share on other sites More sharing options...
Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 Thanks for the in put guys Ive already got a decent fmic...turbo.. manifold...brakes amd a few other bits and bobs. - - - Updated - - - Thats a good options.. didnt really think of that. Could just keep my eye out Quote Link to comment Share on other sites More sharing options...
marc_p Posted October 30, 2013 Share Posted October 30, 2013 Thanks for the in put guys Ive already got a decent fmic...turbo.. manifold...brakes amd a few other bits and bobs. Will also need: - ECU - Fuel pump - FPR - Wastegate/s - Oil Cooler Plus all the other little bits that that are recommended and you will want to replace whilst you are there. Quote Link to comment Share on other sites More sharing options...
Big Supes Posted October 30, 2013 Share Posted October 30, 2013 For around 500bhp... FMIC Injectors FPR Wideband AFR Boost gauge Heavy duty clutch Uprated head bolts Cams Manifold Turbo Turbo elbow Oil cooler (not essential though) ECU and map sensor Fuel pump Anything else I'm missing? Kinda wouldn't mind getting a list down for my own reference. Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 30, 2013 Share Posted October 30, 2013 Cams won't be necessary to go single but will help with power if there's change left over. Save for your ecu, fuel system and turbo kit then save that amount again for little bits and bobs. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 30, 2013 Share Posted October 30, 2013 Forget the cams .. no need for sub-600 bhp. As Kaan said : ECU, turbo kit, fuel system and a proper clutch should do the job. Quote Link to comment Share on other sites More sharing options...
Big Supes Posted October 30, 2013 Share Posted October 30, 2013 Cams won't be necessary to go single but will help with power if there's change left over. Save for your ecu, fuel system and turbo kit then save that amount again for little bits and bobs. Forget the cams .. no need for sub-600 bhp. As Kaan said : ECU, turbo kit, fuel system and a proper clutch should do the job. Ta. Quote Link to comment Share on other sites More sharing options...
Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 You guys love this stuff.... i best get buying... i could be a single man in more ways than one soon Quote Link to comment Share on other sites More sharing options...
Big Supes Posted October 30, 2013 Share Posted October 30, 2013 You guys love this stuff.... i best get buying... i could be a single man in more ways than one soon PMSL! I may lose a turbo... and a kidney on the black market to pay for all of this stuff! Quote Link to comment Share on other sites More sharing options...
Guest thejamman12 Posted October 30, 2013 Share Posted October 30, 2013 Haha.... sure some one will swap their turbo for a kidney??? Quote Link to comment Share on other sites More sharing options...
JasonR24 Posted October 30, 2013 Share Posted October 30, 2013 Haha.... sure some one will swap their turbo for a kidney??? I'd swap my kidney but for a supra Quote Link to comment Share on other sites More sharing options...
Big Supes Posted October 30, 2013 Share Posted October 30, 2013 I would more than likely eat pillow for a big single... man... I mean, Supra. Quote Link to comment Share on other sites More sharing options...
tooquicktostop Posted October 30, 2013 Share Posted October 30, 2013 6.5K Buys you a full car, and a nice one at that, already running 500BHP on a fast spooling GT35 Quote Link to comment Share on other sites More sharing options...
Guest silvianc Posted October 30, 2013 Share Posted October 30, 2013 (edited) Yoink. No polluting a tech article with shameless advertising of broken turbos Plus Garrett don't make the T04Z, that's a HKS brand. Edited October 30, 2013 by Ian C (see edit history) Quote Link to comment Share on other sites More sharing options...
imi Posted October 30, 2013 Share Posted October 30, 2013 6.5K Buys you a full car, and a nice one at that, already running 500BHP on a fast spooling GT35 agree - probably a easiest way to go Single.... Quote Link to comment Share on other sites More sharing options...
