Enkei abc exclusives and big brakes
Pharskie
I have been trying to find a definitive answer but haven't as of yet so hoping you guys can help. I'm running enkei Abc exclusive wheels 18x9 +32 front 18x10 +32 rear. I have the small 2/1 brakes fitted now and have 13 mm clearance between the brake and wheel. Will I be able to fit big brakes with my setup?image
If you are going for OEM Big Brakes, then I really doubt they will fit, they are a lot bigger than J-Spec's
Your best bet is to find someone local ( I know that may not be the easiest thing in Australia) with Big Brakes that is willing for you to try your wheel over them, but I am confident they are not going to clear
