Finished my build, spec list added
Parry_10
Finished my car off this weekend its off to SRD Monday 4th for a full check over and to make sure everything is spot on and the last little bits finishing. Also needs some wiring and syvecs ecu, sensors and toucan install. I want to get a pair of the srd engine bay boxes as well and have them in gloss black. Heres a few pics for you guys not the best but you get the idea...
Chris
Spec list:
Shell
Nur motorsport Carbon fibre rear arches, 50mm wider each side.
Nur motorsport Carbon front arches, 40mm wider each side.
Hybrid Full Carbon Doors
Seibon Full Carbon Tailgate
RMM front spoiler
Facelift front & rear lights
Clear indicators
Stubby aerial
Zunsport Front Grille
Custom bonnet vents, aerocatches
Ridox carbon boot lip
Wheels, Suspension + Brakes
Tein flex coilovers
Fiske 18” forged alloys, 11” fronts 265 tyres, 12” rears 335 tyres
KAD 6 pot front,4 pot rear, AP racing discs, porterfield pads. Refurbed with new seals and stainless pistons.
Engine + Drivetrain
Stage 2 head- Fully ported + polished, brian crower titanium springs and retainers, new teflon coated valve stem seals
Tomei 264 cams 9.5 lift
ARP headstuds
All gaskets new toyota gaskets inc headgasket
Stock bottom end
Greddy intake manifold- fully port matched
Q45 throttle body 90mm
NGK racing spark plugs
6 speed v160 gearbox
Big case UK spec auto LSD with correct shafts
ACT paddle clutch and ACT Flywheel
Polished cam covers with custom -12 breathers and braided lines with fittings
Garage whifbitz adjustable cam pulleys
Billet timing belt tensioner
Greddy pulley set, billet idler pulley
Cooling
Greddy 4” intercooler 3” custom pipework
SRD twin electric fan kit
TRD thermostat
SRD alumimum rad
Mocal oil and power steering coolers
Thermosleeve
Custom coolant overflow tank
Fuel system
Twin bosche 044 in tank fuel pump set up
Whifbitz id1000 injector and fuel rail set up
Twin fuel filter set up with all fuel lines upgraded to braided lines aero fittings etc
Aeromotive FPR with gauge
Exhaust
Power house racing 4” system, custom 4” downpipe
Interior
Fully flocked interior
Evo 9 MR edition recaro seats
Nardi steering wheel with boss and quick release hub
Other
Line lock kit
Carbon fibre slam panel
Carbon fibre spark plug cover
Hks racing bov
Turbo and ECU
Comp billet turbo- 6765, .81ar, 3”v band
T4 dei turbo blanket
HKS 60mm wastegate
HKS exhaust manifold
Syvecs toucan screen
All syvecs sensors
Syvecs ECU
Edited by Parry_10 (see edit history)
  • Replies 74
Future plans? Enjoy it? break it? or sell it and jump on the GTR bandwagon? :D I look forward to its first dyno run... post SRD.
Just want to enjoy it and go to as many events as I can and nurburgring next year.
- - - Updated - - -
Did you buy mitchells old phone :D
:D
