injectors and fuel rail
scott87
The rail will not fit as the injector port spacing is different on the TT, been there tried that with an aftermarket tt rail i borrowed last week
7MGTE injectors can be had fairly cheap
Especially if you know someone nice !!
Like I said mate the bolt pattern is different, what tt is it uk or jspec?
I have a jspec tt rail plus jets, purchased for the same idea, it's still in my garage what you want is some 7mgte jets or some rx7 550s
Dam yer the rail is from a jspec tt, i assumed that the injectors would simply be the same fitment but larger cc.
Off to the mkiii forum for injectors then...
scott, you will need to make/buy a resistor pack for the 7Mgte jets they are not just plug and play as they are Low Imp. 6 Ohm 50W per injector in series does the trick nicely. Or if you are really lucky look for some 1989 RX7 turbo 2 injectors. They are 550cc and High Imp so no need for resistor packs.
Either way get your head into the NAT section of the club, all these lessons have been learned over and over again i am as guilty as any but there is plenty of reading and information to steer you right!!
Spot on thanks.
I may just look at buying some that larger ones that will be a direct fit new.
Speak to Rich.2211 on here as he bought some from us ebay for a decent price, something i wish i had done to start with
Or
If youve got time on your hands my 7mgte injectors and resisters will be coming off mine end of december
