scott87 Posted October 26, 2013 Share Posted October 26, 2013 Can someone point me to the correct files for my map-ecu (ecu) It is the original ecu not 2 or 3. I need the base ap for a non turbo car, which one is it from this list: http://www.mapecu.co.nz/2013/01/base-tables/ And i need the wiring diagram and there are 2 ge options, i assume i am choosing the jdm one: http://www.mapecu.co.nz/2013/01/wiring-diagrams/ Quote Link to comment Share on other sites More sharing options...
Shane Posted October 26, 2013 Share Posted October 26, 2013 If you post on the map forum, Mapman will normally get back to you within a day or so and point you in the right direction. I have one of the originals too, what PC/OS are you running it on and did you manage to get it to run with a usb to 232 lead? Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 26, 2013 Author Share Posted October 26, 2013 If you post on the map forum, Mapman will normally get back to you within a day or so and point you in the right direction. I have one of the originals too, what PC/OS are you running it on and did you manage to get it to run with a usb to 232 lead? I havent even installed the ecu yet, nor did i realise there was an ecu forum I will be running mapcal on my mac using wine to run the .exe file. Then i will be using a usb serial convertor. Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 26, 2013 Share Posted October 26, 2013 So, out of interest, is this just to fault-find from the ECU? Or can you actually adjust the stock settings? Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 26, 2013 Author Share Posted October 26, 2013 So, out of interest, is this just to fault-find from the ECU? Or can you actually adjust the stock settings? Its a piggyback ecu, Im going to map the stock na with bigger injectors to learn how to do it, then ill be ready to map once i go single turbo... Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 26, 2013 Share Posted October 26, 2013 (edited) Oh right . . . I knew the Mk3 ECU couldn't be re-programmed . . . wondered if the Mk4 one was different . . . obviously not At the risk of hi-jacking your thread . . . but on the subject of ECUs . . . The Mk3 ones are really bullet proof . . . they practically never go wrong EXCEPT - I gather the ones fitted to the JZA70 cars with the 1JZ engines suffer from faulty capacitors, and therefore go wrong quite a lot Are the Mk4 ECUs pretty reliable? Edited October 26, 2013 by Roger NE (see edit history) Quote Link to comment Share on other sites More sharing options...
stevie_b Posted October 26, 2013 Share Posted October 26, 2013 From my several years on here, I've never heard of a single fault being traced to a broken stock ECU, so yes pretty bullet proof. Sounds like the capacitor plague got to the JZA70 ones. Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 26, 2013 Author Share Posted October 26, 2013 I have only ever heard of stock ecu failures with sw20 mr2s. Also can someone confirm if i need to plug in the manifold pressure sensor if im running the ecu on the na for the time being..... Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 26, 2013 Share Posted October 26, 2013 That's good to hear ! Thanks chaps Quote Link to comment Share on other sites More sharing options...
Shane Posted October 26, 2013 Share Posted October 26, 2013 I havent even installed the ecu yet, nor did i realise there was an ecu forum I will be running mapcal on my mac using wine to run the .exe file. Then i will be using a usb serial convertor. OK, click on the 1st link in your original post and the third tab down on the left will take you to the forums, Map ecu man is really good at providing support for the whole range and responds very quickly. Quote Link to comment Share on other sites More sharing options...
Shane Posted October 26, 2013 Share Posted October 26, 2013 From my several years on here, I've never heard of a single fault being traced to a broken stock ECU, so yes pretty bullet proof. Sounds like the capacitor plague got to the JZA70 ones. I had a GE ecu die on me, the fuel pump side of things died during a really bad, rushed jump start session and I suspect loose battery terms on my car saw it off. I spent quite a bit of time and money trying to get to the bottom of it until I found a replacement ecu. Quote Link to comment Share on other sites More sharing options...
