Kim's SRD Billet 6766 Torque Monster Build
Lee P
Have a very nice build going on at the moment for one of our customers overseas
This is the car as it came in, bpu Euro spec car
Spec will be:
Sound Performance Torque Monster Turbo Kit
Precision Billet 6766 CEA 1.0 A/R
Sound Performance Quick Spool Valve
4" DP and MP with Waste gate Recirc
Tanable Medallion Exhaust System
SRD Custom Exhaust cut out
HKS SSQV with custom recirc
SRD Stage 1 Built Block
-87mm Mahle Pistons
-BC Pro Series Rods
-ACL Race Bearings
-ARP Main Stud Kit
-Polished Crankshaft
-Fully balanced
New Oil Pump
New Water Pump
New Oil Squirters
New Core Plugs
Full Gasket Set
Fluidamper Crank Pulley
SRD Stage 3 Head
-Full Refresh with new seals
-BC Uprated Springs with Titanium Retainers
-Port and Polish
-SRD Stage 1 cams
L19 Head Stud Kit
Titan Cam Gears
Gates Timing Belt
MVP Billet Tensioner Bracket
TRD Thermostat
Mishimoto Radiator Hose Kit
EGR Delete
SRD Ethanol Fuel System
-Asnu 1100cc Injectors
-Top Feed Fuel Rail
-CustomTeflon Lines and Speedflow fittings
-Aeromotive FPR Kit
-Twin Walbro 485 Pumps
Syvecs S6 ECU Setup
-All sensors
-Trac Control
-Toucan Display
TRD LSD
SRD Overflow Tank
SRD Intercooler Plate
SRD Custom Oil cooler Kit
Stoptech Brake discs front and rear
Brembro Spec Hawk Pads
Goodrich Braided Brake Lines
PHR Line Lock Kit
Alpine INE-W925R
Alpine Reverse Camera
Kim wants an OEM look but a bit smarter so will be painted engine parts but no polishing.
Will Update as the build progresses
Edited by Lee P (see edit history)
  • Replies 135
Posted Images
Is this the black car that I saw you had to one side yesterday Lee? Looks like this should be a good build shall be following with interest :D
Yes it is :)
nice,wha power will this be putting out?
We are hopeing for 700hp and very fast spool, these kits have been used in the USA and done very well.
I swear someone made 900 on 108 Octane race fuel and a cast manifold/6766 setup in the USA. Beasty Turbo! Sick project mate, wish I was building it lol.
Yeah it is possible with the USA figures, seen a few 800hp with ethanol.
We will be pushing for as much as we can so will be good to see what it does. Its really the torque that's important with this, nice fast spooling, hard hitting setup :)
Just come back you know you want to :D
I will be following this build mate, as I have this turbo in mind for replacing my current unit. :)
I'm sure it will push much more than 700bhp on a built engine with your Stage 3 head. Try to convince Kim to go for Stage 2 or Stage 3 cams ;)
It probably will but it is a log manifold which is more of a restriction, it will need the ethanol to deal with the heat.
Kim wants it to still be very streetable and stock like.
Engine bay will be subtle and with a factory look.
  • 2 weeks later...
The car used to be red and had a re spray but the engine bay wasn't finished off.
We prepped it ready for some paint
This is the engine bay done but still the front left to do
Usual practice for us with engine builds is to make everything look nice and new.
Kim wanted a stock look so most things are black and silver.
Parts prepped and painted ready for assembly
