Tayfun.tugra Posted October 24, 2013 Share Posted October 24, 2013 (edited) So I found this blue switch and tried to follow the wires back but with no luck. Any ideas as to what it does? I cant see anything as to what it could be. . . . Sorry I cant get the image size down so I have to post it like this. Edited October 24, 2013 by Tayfun.tugra (see edit history) Link to comment Share on other sites More sharing options...
Thorin Posted October 24, 2013 Share Posted October 24, 2013 Arms the bomb. (or possibly rear fog?) Link to comment Share on other sites More sharing options...
David P Posted October 24, 2013 Share Posted October 24, 2013 Frog light. Link to comment Share on other sites More sharing options...
listy Posted October 24, 2013 Share Posted October 24, 2013 It arms the ejecto-seato cuz Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 24, 2013 Share Posted October 24, 2013 Switch it on and see what happens. Link to comment Share on other sites More sharing options...
Kaan W Posted October 24, 2013 Share Posted October 24, 2013 Nice! Thanks for sharing. Link to comment Share on other sites More sharing options...
Lbm Posted October 24, 2013 Share Posted October 24, 2013 Kaan W said: Nice! Thanks for sharing. Which bit is nice? Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted October 24, 2013 Author Share Posted October 24, 2013 Not the rear fog unfortunately. Or the bomb. Or the ejecto seato aha. I tried it in numerous conditions. .no luck Link to comment Share on other sites More sharing options...
Kaan W Posted October 24, 2013 Share Posted October 24, 2013 (edited) Lbm said: Which bit is nice? All of it really but mainly the switch, stunning! Perhaps when you switch it on it lights up, thats all. Edited October 24, 2013 by Kaan W (see edit history) Link to comment Share on other sites More sharing options...
Alex Posted October 24, 2013 Share Posted October 24, 2013 It says on it - in pictures - it's a light relay, but you're missing the GND wire...if it had additional front lights like PIAA spots the Japs often add then it could have been for them - but more likely the rear fog unless you have another rear fog. Link to comment Share on other sites More sharing options...
Lbm Posted October 24, 2013 Share Posted October 24, 2013 Kaan W said: All of it really but mainly the switch, stunning! I'm an idiot. Link to comment Share on other sites More sharing options...
TT Paul Posted October 24, 2013 Share Posted October 24, 2013 its a add on of sorts.. if you can't find what it does bin it.. or use it for something else! if you don't use it trace/isolate the wiring as it could short if has a 12v feed. Link to comment Share on other sites More sharing options...
straightsix Posted October 24, 2013 Share Posted October 24, 2013 A stab in the dark here - I fitted a switch to my electric aerial as I didn't want it popping up when the head unit was switched on unless I was actually using the radio. I doubt it's for that purpose but just throwing an idea in the pot Link to comment Share on other sites More sharing options...
ScottC Posted October 24, 2013 Share Posted October 24, 2013 (edited) Alex said: It says on it - in pictures - it's a light relay, but you're missing the GND wire...if it had additional front lights like PIAA spots the Japs often add then it could have been for them - but more likely the rear fog unless you have another rear fog. The GND is just to make the switch light up when it's turned on Edited October 24, 2013 by ScottC (see edit history) Link to comment Share on other sites More sharing options...
LOGIE Posted October 24, 2013 Share Posted October 24, 2013 Does the car start with the switch in both posns? I had a home made immobiliser on a peugeot like that. It was wired to ignition but well hidden. Link to comment Share on other sites More sharing options...
straightsix Posted October 24, 2013 Share Posted October 24, 2013 Alex said: It says on it - in pictures - it's a light relay, but you're missing the GND wire...if it had additional front lights like PIAA spots the Japs often add then it could have been for them - but more likely the rear fog unless you have another rear fog. It's a switch - not a 'relay' The 'ACC' terminal is for 'Accessory' - in most cases lights of some description (hence the picture). I'd like to know if the OP already has a fog switch somewhere else or even a working rear foglamp at the moment so he can rule out if it's just a case of a blown fog bulb or something else. Link to comment Share on other sites More sharing options...
SkydiveMacca Posted October 27, 2013 Share Posted October 27, 2013 Look under the "chassy" for screw holes. Might have been for an under car neon kit that foolishly got removed. Switch was left so as not leave a gaping hole in the trim. Link to comment Share on other sites More sharing options...
Tayfun.tugra Posted October 27, 2013 Author Share Posted October 27, 2013 LOGIE said: Does the car start with the switch in both posns? I had a home made immobiliser on a peugeot like that. It was wired to ignition but well hidden. I also thought it had something to do with the alarm system... then I took a step back and realised I had quite a sophisticated system fitted. straightsix said: It's a switch - not a 'relay' The 'ACC' terminal is for 'Accessory' - in most cases lights of some description (hence the picture). I'd like to know if the OP already has a fog switch somewhere else or even a working rear foglamp at the moment so he can rule out if it's just a case of a blown fog bulb or something else. This is what I investigated the most. The car was imported in 1999/2000 so I have always wondered how it passed the MOT year after year without a fog light fitted, then its always possible to have a friendly MOT technician * uhum* SkydiveMacca said: Look under the "chassy" for screw holes. Might have been for an under car neon kit that foolishly got removed. Switch was left so as not leave a gaping hole in the trim. As its cropped up so many times as to do with fog lights/neon etc I'll spend some more tuesday (not raining) aiming in that direction. will let you know how it goes on. Link to comment Share on other sites More sharing options...
