Lee P Posted October 24, 2013 Share Posted October 24, 2013 (edited) We stock the Toyota coil pack clips but they are not always suitable as the stock wires can get very brittle and pins can break We can now offer the coil pack clips with wires so they can be soldered to your loom and remove the broken ends. We have been using these for a long time now and they fit much better onto the coil. £6.60 each + del Edited December 2, 2015 by Lee P (see edit history) Quote Link to comment Share on other sites More sharing options...
Iky Posted November 27, 2013 Share Posted November 27, 2013 I'll take a set of these please. Sent you a pm Lee. Quote Link to comment Share on other sites More sharing options...
Richienoble Posted January 14, 2014 Share Posted January 14, 2014 Do these fit the vvti coil packs?? Quote Link to comment Share on other sites More sharing options...
Lee P Posted January 14, 2014 Author Share Posted January 14, 2014 Do these fit the vvti coil packs?? Yes they do Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted February 24, 2014 Share Posted February 24, 2014 Lee please PM me a price for a full set for my pre face lift twin turbo including delivery. Quote Link to comment Share on other sites More sharing options...
inazone Posted March 24, 2014 Share Posted March 24, 2014 can the plugs be dismantled and fitted directly to the stock pins, as my wires/pins are ok its just the plastic outer casing that is starting to fall apart. Quote Link to comment Share on other sites More sharing options...
Lee P Posted March 25, 2014 Author Share Posted March 25, 2014 can the plugs be dismantled and fitted directly to the stock pins, as my wires/pins are ok its just the plastic outer casing that is starting to fall apart. No, you can't use the stock pins If your pins are ok you can use the Toyota plugs which we also have in stock but they are a bit more money What you need to be looking at though is the wires as they go very brittle and the casing cracks causing a short. Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted January 25, 2015 Share Posted January 25, 2015 I'll take six of these, you have PM Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted April 24, 2016 Share Posted April 24, 2016 I would like a full set of these if still possible? I will PM now. Quote Link to comment Share on other sites More sharing options...
