j_jza80 Posted October 24, 2013 Share Posted October 24, 2013 I've just noticed something unusual about the Zent JGTC Supra. The headlights are quite clearly marked 'TRD HID HEAD LAMP KIT'. Is this something that was available to buy? and if so, was it just the HID bulbs/ballasts, or did it include these unusual headlights/inserts? A set of these would really freshen the front end of the Supra IMO, and would be a good alternative to the Abflug ones. Quote Link to comment Share on other sites More sharing options...
Rob_Mitchell Posted October 24, 2013 Share Posted October 24, 2013 Might sound dumb but they look like a sticker to me Quote Link to comment Share on other sites More sharing options...
LOGIE Posted October 24, 2013 Share Posted October 24, 2013 Might sound dumb but they look like a sticker to meI was thinking that, they look different, but not better than stock. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 24, 2013 Share Posted October 24, 2013 Since that isn't actually a Supra, it's entirely possible they're not Supra lights. Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 24, 2013 Share Posted October 24, 2013 Might sound dumb but they look like a sticker to me I would have to agree with you on that one. Looks like a bit of metal with a sticker over it and a hole cut out for the light. If they are a proper insert they would look cool though Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 24, 2013 Author Share Posted October 24, 2013 Since that isn't actually a Supra, it's entirely possible they're not Supra lights. True, but then why bother with the TRD HID stickers? They look like inserts of some description to me, but obviously it's likely that they only resemble Supra headlights. But why change the design from the stock look if that's the case? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 24, 2013 Share Posted October 24, 2013 True, but then why bother with the TRD HID stickers? They look like inserts of some description to me, but obviously it's likely that they only resemble Supra headlights. But why change the design from the stock look if that's the case? Weight saving maybe? It could be that the lighting units themselves are the TRD product I suppose. Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 24, 2013 Share Posted October 24, 2013 Oh, and aerodynamics of course. The lights on that race car sit flush with the bumper. They don't on a normal Supra do they? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 24, 2013 Author Share Posted October 24, 2013 They're real: Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted October 24, 2013 Share Posted October 24, 2013 Since that isn't actually a Supra Do you mean because it uses a 3S-GTE instead of a 2JZ-GTE? Or because of the extensive chassis & body modifications? If it's not a Supra, what model of car is it? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted October 24, 2013 Share Posted October 24, 2013 Do you mean because it uses a 3S-GTE instead of a 2JZ-GTE? Or because of the extensive chassis & body modifications? If it's not a Supra, what model of car is it? It's a race car that looks like a Supra. The chassis hasn't been modified, it's been built bespoke from the ground up. Quote Link to comment Share on other sites More sharing options...
clay Posted October 24, 2013 Share Posted October 24, 2013 Might sound dumb but they look like a sticker to me If it was a sticker rob. how would he see wear he was going in the dark. YOU DUM ASS LOL Quote Link to comment Share on other sites More sharing options...
st3ven1 Posted October 24, 2013 Share Posted October 24, 2013 (edited) It's a race car that looks like a Supra. The chassis hasn't been modified, it's been built bespoke from the ground up. Not from what I've read. There were actually lots of regulations not allowing them to modify the original chassis layout, engine location, engine orientation(hence why they had to rotate the 3S-GTE engine to keep the cylinders running front to back like the 2JZ) or suspension configuration. They were however allowed to move the suspension inboard(as they were allowed to move the mounting points) to reduce un-sprung weight. Regulations also made them move the fuel tank to within the wheel base, which in turn allowed them significant modification of the rear suspension, resulting in the rear suspension be moved to an inboard set up similar to the front. The only modification to the chassis(that were allowed) were the ones to accommodate the new fuel tank location. Edited October 24, 2013 by st3ven1 Spelling. (see edit history) Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 24, 2013 Author Share Posted October 24, 2013 It's possible you're both right, as the JGTC Supras changed significantly over the years. The later ones used V8s, and one even had a hybrid engine. The early ones resemble stock body cars with arch extensions, and the later ones look totally bespoke. Quote Link to comment Share on other sites More sharing options...
Scott Posted October 24, 2013 Share Posted October 24, 2013 The TRD HID kit is just an HID kit. It was a VERY expensive option from the factory. I remember Nic talking about it years ago. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted October 24, 2013 Author Share Posted October 24, 2013 Thanks hopefully Nic will pitch in if he sees this. But, if that is the case, then what are these headlights? they seem to be on a lot of the later JGTC Supras, so they're definitely not a one off. I wonder if they would have come as a part of a kit from TRD specifically for the race cars? Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted October 24, 2013 Share Posted October 24, 2013 They're real: http://i297.photobucket.com/albums/mm203/j_s14a/JGTCSupra_zpsc903963c.jpg That is absolutely stunning. Most of the JGTC/Super GT Supras had that style of headlights. But most of the cars were like the American stock cars - resembling the road versions mainly just in looks. Now THESE are sexy headlights, probably even rarer though; http://racecar2.web.fc2.com/fNCRCsupraHVR21.jpg Quote Link to comment Share on other sites More sharing options...
Fizzy T Posted October 24, 2013 Share Posted October 24, 2013 The internet says "NOPE". Quote Link to comment Share on other sites More sharing options...
Herb Posted October 24, 2013 Share Posted October 24, 2013 Yes - very interested about Nic's opinion on that HID topic. There was a HID kit available through TRD - they sometimes turn up on ebay for a lot of money. But it's just the ballasts and the bulbs... Quote Link to comment Share on other sites More sharing options...
Scott Posted October 24, 2013 Share Posted October 24, 2013 Yes - very interested about Nic's opinion on that HID topic. There was a HID kit available through TRD - they sometimes turn up on ebay for a lot of money. But it's just the ballasts and the bulbs... That's the very one I remember hearing about. Quote Link to comment Share on other sites More sharing options...
Rob W Posted October 24, 2013 Share Posted October 24, 2013 From what I've just read on an old thread, the TRD kit is just the hid ballasts not with the light inserts/overlays. Quote Link to comment Share on other sites More sharing options...
