ccssupra Posted October 23, 2013 Share Posted October 23, 2013 Alright guys, I want to get rid of the OEM open diff and swap it out with an OEM LSD. It is possible with an automatic? Im not sure if will affect anything electronically! Quote Link to comment Share on other sites More sharing options...
SPG Posted October 23, 2013 Share Posted October 23, 2013 you can do a straight swap with the Auto LSD A02B, this wont have any impact on the electrical system and will be a bolt for bolt straight replacement, the only thing that will alter is the handling characteristics of your Sup, and your smile factor . Have a little search on the subject as well, there will be a walk through somewhere Quote Link to comment Share on other sites More sharing options...
LOGIE Posted October 23, 2013 Share Posted October 23, 2013 My uneducated guess is you will be fine swapping them. Its been done loads before. Are you swapping the diff complete in its case? or the diff itself? Quote Link to comment Share on other sites More sharing options...
ccssupra Posted October 23, 2013 Author Share Posted October 23, 2013 Thanks guys Depends what I see on the forum really, its my first rwd open diff car and I can certainly tell the difference but I would like to keep it stock! I'll keep scanning the for sale section. Quote Link to comment Share on other sites More sharing options...
Pulley Posted October 27, 2013 Share Posted October 27, 2013 All you need to do is confirm wether you have a large case or small A at the beginning of the diff code is small, B is for big case Then there's the ratio 01,02,03 ect ect the the final letter dictates open A or LSD B If you find another diff of same case size but wrong gear ratio to wot you currently have, it's fairly straight forewords to swap the "core" over and keep your current crown and pinion as the cores dime Simons (open and LSD) are the same Hope this helps Quote Link to comment Share on other sites More sharing options...
paulj1 Posted October 27, 2013 Share Posted October 27, 2013 When you change the diff mate if it's anything like mine the drive shafts where a pig to break free and the diffs are heavier than they look lol Quote Link to comment Share on other sites More sharing options...
