chris2o2 Posted October 23, 2013 Share Posted October 23, 2013 Before i break anything - is it just the two 10mm bolts then pull and get access to the bolts underneath the fuse ? Never let numptys use your car to jump start theirs . Thanks Link to comment Share on other sites More sharing options...
Scott Posted October 23, 2013 Share Posted October 23, 2013 Before i break anything - is it just the two 10mm bolts then pull and get access to the bolts underneath the fuse ? Never let numptys use your car to jump start theirs . Thanks Sounds about right mate. You unbolt the inner fuse holder from the fuse box to allow access underneath. Once in there it's 2 small nuts that hold the fuse in place. Link to comment Share on other sites More sharing options...
chris2o2 Posted October 23, 2013 Author Share Posted October 23, 2013 Just these two ? I hate cars btw . Thanks Scott. Link to comment Share on other sites More sharing options...
Scott Posted October 23, 2013 Share Posted October 23, 2013 [ATTACH=CONFIG]176149[/ATTACH] Just these two ? I f***ing hate cars btw . Thanks Scott. No bud, I believe there are 3 on the top side. One under the red "plus" cap. Should be a nut. Once that's off, there are 2 nuts holding in the actual fuse itself. Link to comment Share on other sites More sharing options...
chris2o2 Posted October 23, 2013 Author Share Posted October 23, 2013 No bud, I believe there are 3 on the top side. One under the red "plus" cap. Should be a nut. Once that's off, there are 2 nuts holding in the actual fuse itself. Sneaky wee nut hiding away under a cap , damnit . Some man Thanks mate . Link to comment Share on other sites More sharing options...
Scott Posted October 23, 2013 Share Posted October 23, 2013 Sneaky wee nut hiding away under a cap , damnit . Some man Thanks mate . No worries, they don't like to make these things too obvious Make sure that particular nut/bolt assy is particularly clean when you're putting it back together. This is your positive connection from the battery to the fuses Link to comment Share on other sites More sharing options...
