120amp fuse removal .
chris2o2
Before i break anything - is it just the two 10mm bolts then pull and get access to the bolts underneath the fuse ?
Never let numptys use your car to jump start theirs .
:( Thanks
Sounds about right mate. You unbolt the inner fuse holder from the fuse box to allow access underneath. Once in there it's 2 small nuts that hold the fuse in place.
[ATTACH=CONFIG]176149[/ATTACH]
Just these two ?
:sly: I f***ing hate cars btw .
Thanks Scott.
No bud, I believe there are 3 on the top side. One under the red "plus" cap. Should be a nut.
Once that's off, there are 2 nuts holding in the actual fuse itself.
Sneaky wee nut hiding away under a cap , damnit .
Some man
Thanks mate .
No worries, they don't like to make these things too obvious :D
Make sure that particular nut/bolt assy is particularly clean when you're putting it back together. This is your positive connection from the battery to the fuses :)
