scott87 Posted October 22, 2013 Share Posted October 22, 2013 Ok, so im going na-t and have sourced a turbo and wastgate. im using a 7psi spring and looking to keep stock internals. Im going to get an in car boost gauge to monitor boost but what boost controller do i need or how do i ensure that i run the correct boost for the engine. Can i get one of the manual ones and leave it set at the correct position under the bonnet and if so can someone post a link to i know the correct thing im looking for please. Quote Link to comment Share on other sites More sharing options...
Fly Posted October 22, 2013 Share Posted October 22, 2013 Hi mate, Do you need to boost over 7 PSI? Are you planning/changing your fuel injectors or fuel pump? I have never used a manual boost controller so i cannot comment there. Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 23, 2013 Author Share Posted October 23, 2013 Nope im planning on running a 7psi wastegate and keeping a completely stock na lump. Quote Link to comment Share on other sites More sharing options...
MattP Posted October 23, 2013 Share Posted October 23, 2013 Dont ever fit a MBC they are the Devil Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 23, 2013 Author Share Posted October 23, 2013 Dont ever fit a MBC they are the Devil Ok thanks. So am i right in thinking that just fitting a 7psi wastegate should do the job then? Quote Link to comment Share on other sites More sharing options...
MattP Posted October 23, 2013 Share Posted October 23, 2013 (edited) Consult the bible .....http://www.mkivsupra.net/vbb/showthread.php?279627-FOSTA-S-how-to-fit-a-basic-NA-T-kit It appears the wastegate spring is the basic method of control but im no expert Edited October 23, 2013 by MattP (see edit history) Quote Link to comment Share on other sites More sharing options...
scott87 Posted October 25, 2013 Author Share Posted October 25, 2013 Been told a boost controller is a must by someone. Is this true, would it not be a good idea to have the wastgate set to 7psi, hoping thats ok for stock na engine, then set then boost controller aswell just in case one were to fail.> Quote Link to comment Share on other sites More sharing options...
Rich.2211 Posted October 25, 2013 Share Posted October 25, 2013 I'm not a running a boost controller on mine, boost is being controlled solely by the wastegate spring. It isn't the best method, which is the reason I'm in the throws of buying a GReddy Profec B Spec II, but it works fine. Quote Link to comment Share on other sites More sharing options...
