Tri xenon hid
Richienoble
Me either. HID system (aftermarket, even the OEM ones on my Disco 3) only use the stock wiring as a "signal" to turn the lights on, as all the power is generated by the Ballast.
Its not like the days of sticking in 120 Watt Bulbs into a car that's designed to use 55 Watt - that will melt the looms!
Main beam shouldn't be Xenon. Due to the charateristics required - like flashing. Well I'm yet to see an after market kit that allows for that.
Mine is Bi-Xenon and tbh you'll not need a full beam.
I have fitted and tested the main/full beam functions ok not sure how long it will last for tho only time will tell haha.
