Jellybean Posted October 16, 2013 Share Posted October 16, 2013 Did anybody do this mod yet? Was thinking it may lighten up my clutch pedal M/C from a FZJ75 / FZJ80 Cruiser had the same flange and a reservoir which could be swapped for the JZA80 one http://www.toymods.org.au/forums/tech-conversions/78805-how-make-3-4-jza80-clutch-master-cylinder.html Quote Link to comment Share on other sites More sharing options...
Pulley Posted October 21, 2013 Share Posted October 21, 2013 I've just done this mod to generate enough travel to operate my triple plate osgiken (fully disengage and engage ) Easy mod , I bought 2 land cruiser masters so I have a spare converted one actually Quote Link to comment Share on other sites More sharing options...
Guest SupraV8 Posted October 21, 2013 Share Posted October 21, 2013 It will make the pedal heavier, not lighter. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2013 Share Posted October 22, 2013 If you want a really light clutch put a servo on it. Skyline R33 and R34 GTR's have a clutch servo as stock, but few seem to realize this. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 22, 2013 Share Posted October 22, 2013 It will make the pedal heavier, not lighter. Correct, and you may well need a pedal stop to avoid bearing over travel if you use a bigger master to make a marginal setup release fully. Vice versa a smaller bore master, whilst giving a lighter pedal, may not fully release the clutch.... Quote Link to comment Share on other sites More sharing options...
Slutters Posted October 22, 2013 Share Posted October 22, 2013 Also done this mod several months ago, fixed my issue of my Spec Super Twin not disengaging at high RPM's. If you are ok with a welder, a 2 bolt 38MM wastegate flange can be used to mount to the chassis, then weld 2 studs for the master cylinder to it. Quote Link to comment Share on other sites More sharing options...
