pedrosixfour Posted October 17, 2013 Share Posted October 17, 2013 would there be any sense in upgrade the front brake discs and pads and use the stock TT caliper? If you mean the larger 4 piston caliper then yes. what discs can people recommend ? These. http://www.mkivsupra.net/vbb/showthread.php?294570-New-3G-10-GR-Brake-Disks-(323mm)-For-use-with-4-piston-front-calipers I've a set of as new Hawk high performance pads to suit these disks as well. If I wasn't slightly retarded I wouldn't have any of these available to sell. But I am, so I do! Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 17, 2013 Share Posted October 17, 2013 (edited) on another note .. would there be any sense in upgrade the front brake discs and pads and use the stock TT caliper ? and what discs can people recommend ? Tobias For normal use i wouldn't bother, stock discs and pads work very well, well they did on my car with the uk set up along with braided lines and new brake fluid And they're cheap in comparison to most other set ups, especially the discs Edited October 17, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
Wez Posted October 17, 2013 Share Posted October 17, 2013 would there be any sense in upgrade the front brake discs and pads and use the stock TT caliper ? and what discs can people recommend ? Like this http://www.mkivsupra.net/vbb/showthread.php?179831-Wez-Track-Supra&p=2556063&viewfull=1#post2556063 Of course, but it depends on budget and what they are going to be used for. I would not use this setup on a road car due to the extra noise, on track is different, after a hard track session I pulled into the pits and the dust caps had melted and were dripping onto the floor Quote Link to comment Share on other sites More sharing options...
bignum Posted October 17, 2013 Share Posted October 17, 2013 I`m still on uk`s with race pads, fluid and braided lines, i can`t fault the braking performance and never get fade however we`re getting through a set of front pads in 2 trackdays whereas bigger brakes would probably last longer. Quote Link to comment Share on other sites More sharing options...
