Radiator mounting plate
simbasupra
Hi guys,
Started to take the engine out to do a rebuild and i have found the radiator mounting plate has corroded where the intercooler pipe bracket bolts on. I think this is part of the chassis and is welded on? Has anyone else had this?
Im guessing this part cant be purchased from Toyota. Would i need to get the piece cut out from a scrap supra and weld it on?
I have taken two pics, one from under bonnet and one from under car.
Thanks
Check post 1 for how I replaced mine - http://www.mkivsupra.net/vbb/showthread.php?275510-Kaan-s-3-4-Stroked-Wide-Arch-Supra-project!&
I had to chop it out and weld another one in, if you can be bothered you can drill the 30 something spot welds out and do it that way.
Give Keron a pm he might have one.
Thanks for the info. will see how much a new one is first, then contact keron if its too much.
  • 6 months later...
