girth45 Posted October 14, 2013 Share Posted October 14, 2013 Hi all trying to find the correct bush for my suspension arm, have ordered I set , Incorrect, can anybody help with part no or manufacturers internal bore is 34mm. I ordered the bush for rear a trailing arm front bush ! Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 14, 2013 Share Posted October 14, 2013 I'll also be interested in this as want to do mine Can they be rebushed or do you need to buy whole arm ? Quote Link to comment Share on other sites More sharing options...
Bossco Posted October 14, 2013 Share Posted October 14, 2013 Apparently they can be re-bushed but it's easier to replace the arm. Quote Link to comment Share on other sites More sharing options...
girth45 Posted October 14, 2013 Author Share Posted October 14, 2013 Do they do a poly bush ? If so anybody know part no , or company that can supply. Thought I had ordered correct one , one I have has a 38mm external bore, - - - Updated - - - Do they do a poly bush ? If so anybody know part no , or company that can supply. Thought I had ordered correct one , one I have has a 38mm external bore, - - - Updated - - - Do they do a poly bush ? If so anybody know part no , or company that can supply. Thought I had ordered correct one , one I have has a 38mm external bore, - - - Updated - - - Do they do a poly bush ? If so anybody know part no , or company that can supply. Thought I had ordered correct one , one I have has a 38mm external bore, - - - Updated - - - Do they do a poly bush ? If so anybody know part no , or company that can supply. Thought I had ordered correct one , one I have has a 38mm external bore, Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 14, 2013 Share Posted October 14, 2013 Not sure if you can buy just the bush from Toyota but worth giving Steve Manley a call I think its called the strut rod, i've attached a photo of mine when i changed them, you can read the part number on the arm Quote Link to comment Share on other sites More sharing options...
girth45 Posted October 15, 2013 Author Share Posted October 15, 2013 Been doing some research, and you can't buy bushes seperatly, new arm from Toyota £118+ vat each. P/n 48780-14030. Used approx £25+ vat + delivery. Hope this helps others looking for this. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 15, 2013 Share Posted October 15, 2013 Same as the one i posted the pic of with the part number on it Quote Link to comment Share on other sites More sharing options...
girth45 Posted October 15, 2013 Author Share Posted October 15, 2013 Yes that's the one, thanks for your help and info. Quote Link to comment Share on other sites More sharing options...
markssupra Posted October 15, 2013 Share Posted October 15, 2013 You can get a complete set of polybushes for front and rear from MVP Quote Link to comment Share on other sites More sharing options...
girth45 Posted October 15, 2013 Author Share Posted October 15, 2013 Hi do you have there website details ? Have you used this kit and did it include the bushes I'm after ? Quote Link to comment Share on other sites More sharing options...
girth45 Posted October 15, 2013 Author Share Posted October 15, 2013 Ignore my last question MVP is on this forum, and it seems you can get all the rear bushes from them in there r2 kit, Thanks. Quote Link to comment Share on other sites More sharing options...
SupraLEDrears Posted October 16, 2013 Share Posted October 16, 2013 Toyota told me to replace the whole arm Quote Link to comment Share on other sites More sharing options...
Kirk Posted October 16, 2013 Share Posted October 16, 2013 That's because Toyota don't list them separately where as Lexus do list a few bushes for the SC. Quote Link to comment Share on other sites More sharing options...
markssupra Posted October 16, 2013 Share Posted October 16, 2013 Ignore my last question MVP is on this forum, and it seems you can get all the rear bushes from them in there r2 kit, Thanks. The R2 front and rear kits contain all the bushes required. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted October 16, 2013 Share Posted October 16, 2013 i just had one of these changed, cost me £170 from mr T if i remeber correctly, bk in april it wasHi all trying to find the correct bush for my suspension arm, have ordered I set , Incorrect, can anybody help with part no or manufacturers internal bore is 34mm. [ATTACH=CONFIG]175972[/ATTACH] [ATTACH=CONFIG]175973[/ATTACH] I ordered the bush for rear a trailing arm front bush ! Quote Link to comment Share on other sites More sharing options...
