C_Strike Posted October 14, 2013 Share Posted October 14, 2013 Hey guys. Im getting some strange droning noises from under the bonnet when I rotate the steering wheel, seems to be louder the farther I turn, no notable difference to the ease of rotating the wheel at the moment. Can I sagely assume it's the power steering pump? How much are those going for these days? Is it an easy job? I can get a video if required many thanks in advance Quote Link to comment Share on other sites More sharing options...
listy Posted October 14, 2013 Share Posted October 14, 2013 Check the fluid level first. It may just be a little low. Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 14, 2013 Share Posted October 14, 2013 If it is the pump give CW a call as i think he refurbs them Quote Link to comment Share on other sites More sharing options...
C_Strike Posted October 14, 2013 Author Share Posted October 14, 2013 Oh brilliant thanks guys will get straight on it Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 14, 2013 Share Posted October 14, 2013 Yep check the fluid level, it only needs to be a bit below the line for it to start making noises. Seem to be seeing a few leaks with the age of the cars now. Quote Link to comment Share on other sites More sharing options...
C_Strike Posted October 14, 2013 Author Share Posted October 14, 2013 looks to be a week bit low lol. (first time uploading a pic from phone to forum so not sure it'l work properly) Quote Link to comment Share on other sites More sharing options...
Thorin Posted October 14, 2013 Share Posted October 14, 2013 Top it up and keep an eye on it, but I'd say you've probably got a leak somewhere sadly. Quote Link to comment Share on other sites More sharing options...
C_Strike Posted October 14, 2013 Author Share Posted October 14, 2013 If so, what does that entail? Will I need to sell my past kidney? Or is it a relatively simple system? Quote Link to comment Share on other sites More sharing options...
Camry5Sgte Posted October 15, 2013 Share Posted October 15, 2013 As said, check fluid level. Check the feed and return hoses on the reservoir for dry rotting and cracks as that is common with the heat. Lastly, you can pull out the reservoir and clean out the filter screen inside with a bit of brake cleaner. Quote Link to comment Share on other sites More sharing options...
C_Strike Posted October 15, 2013 Author Share Posted October 15, 2013 What fluid should I put in btw? Quote Link to comment Share on other sites More sharing options...
Pixelfill Posted October 15, 2013 Share Posted October 15, 2013 (edited) What fluid should I put in btw? Power Steering Fluid Stock Dexron III ATF I recommend you stick with Dexron III oil but all makes should be suitable Capacity Interval = ??? To fully Flush it see here http://www.mkivsupra.net/vbb/showthread.php?56684-FAQ-Oil-Fluid-Interval-Capacity-Steering-Brake-Coolant-Diff-Engine Edited October 15, 2013 by Pixelfill (see edit history) Quote Link to comment Share on other sites More sharing options...
Nic Posted October 15, 2013 Share Posted October 15, 2013 Also bleed the system to get rid of any air that may be trapped, see service manual attached.Steering.pdf Quote Link to comment Share on other sites More sharing options...
Guest MKSupraHero Posted October 15, 2013 Share Posted October 15, 2013 Mine always started sounding like a space ship landing and the steering got tight when turning way ahead of the pump going out... Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 16, 2013 Share Posted October 16, 2013 I rebuild PAS pumps that aren't too far gone already. If you catch them early a refurb isn't too expensive. a new pump is about £330 plus VAT. Thanks dnk Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 16, 2013 Share Posted October 16, 2013 I rebuild PAS pumps that aren't too far gone already. If you catch them early a refurb isn't too expensive. a new pump is about £330 plus VAT. Thanks dnk Quote Link to comment Share on other sites More sharing options...
