Max power Posted October 14, 2013 Share Posted October 14, 2013 (edited) Hey you lot, I have a Naturally aspirated manual 94 and I'm wanting to swap my broken engine for a new one. The one I have found is from an automatic transmission naturally aspirated which I have found in a scrap yard. There is no transmission with it just the fly wheel at the back. What do I need to change? Will it fit? (Flywheel) etc thanks. Edited October 14, 2013 by Max power (see edit history) Quote Link to comment Share on other sites More sharing options...
welshbuddy Posted October 14, 2013 Share Posted October 14, 2013 urm what....... manual is alot better then the auto.... dont change it . +the looms and so on and so on, pedals , just leave it. Quote Link to comment Share on other sites More sharing options...
Max power Posted October 14, 2013 Author Share Posted October 14, 2013 (edited) Edited October 14, 2013 by Max power (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 14, 2013 Share Posted October 14, 2013 Well any bits you need you will have from your existing N/A engine . . . but you shouldn't need to change much Think you will need to fit the flywheel from your existing engine . . . but hopefully the Engine Loom is the same on a Manual or Automatic car (someone will no doubt confirm) . . . but in the worse case you can swap the Loom from your old engine. (Generally speaking, when doing an Engine swap, it's easier to leave the loom on the actual Engine, and unplug the ECU and Body connectors) Quote Link to comment Share on other sites More sharing options...
Max power Posted October 14, 2013 Author Share Posted October 14, 2013 Well any bits you need you will have from your existing N/A engine . . . but you shouldn't need to change much Think you will need to fit the flywheel from your existing engine . . . but hopefully the Engine Loom is the same on a Manual or Automatic car (someone will no doubt confirm) . . . but in the worse case you can swap the Loom from your old engine. (Generally speaking, when doing an Engine swap, it's easier to leave the loom on the actual Engine, and unplug the ECU and Body connectors) I was just wondering if everything will fit and line up??? Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 14, 2013 Share Posted October 14, 2013 (edited) I was just wondering if everything will fit and line up??? Yes it's fine. If you don't want to swap the loom over from the manual engine.(I would swap it personally) It's simply a couple of small mods to the gearbox loom to overcome the neutral safety switch on the auto, and to hook up the reverse light, the rest plugs in. You will need to remove the flex plate from the new engine and install the flywheel from your manual car. Be advised that the flywheel bolts will be longer on your Manual, so make sure to use those to bolt the flywheel to the new engine. You will need to install a pilot bearing in the back of the crank on the new engine. They are only a few quid from toyota. The only other thing to be aware of is that there will be extra cooling pipes for the auto box running down the exhaust side of the engine low down. These will drip oil for a while so I would remove them before fitting, plus they are surplus to requirements anyway. Edited October 14, 2013 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
Max power Posted October 14, 2013 Author Share Posted October 14, 2013 Thanks guys. Quote Link to comment Share on other sites More sharing options...
