recommend me a good boost controller
LOGIE
Hi all im on the lookout for a boost controller so as to go full BPU, just wondered what are considered to be the best ie holds accurate boost without spiking and also take temperature into consideration. Ive done a little searching but im reading OLD posts so no up to date info. Ive heard good things about Blitz DSBC and Apexi AVCR but just want to hear from what members would recommend. Cheerz
Edited by LOGIE (see edit history)
only thing i didn't like about them is they are to easy to adjust.
Ie cleaning the car you rotate the knob and accidentally press it inwards, which is easier done than you think and you've changed your boost settings. Had an mr2 come in with cracked piston ringlands because of this. so be careful.
Where the blitz and apexi you have to go out of display options and go into settings so much harder to "accidentially" change something
Tim
