filling the torque converter with ATF
LOGIE
Think about it :) If you lay it on its back and fill it to the level of the top of the neck, when you turn it upright to slide it onto the gearbox, a lot will pour straight back out ;) Just put a pint in. You don't actually need to out any in at all if you don't want to, but you will have to top the `box up as the pump refills the TC. I usually put just under a pint in a new one. A used one will probably already have enough still in it to just refit. if the TC is off a box that's failed you should NOT use it, it's probably full of particulates.
