msupra1 Posted October 12, 2013 Share Posted October 12, 2013 (edited) EDIT: my turn signal nor my hazard lights work now. I clicked the hazard light earlier today worked fine, tonight I did it again just to show a friend how my turn signal isn't working and the hazard suddenly no longer works either. So if both don't work what could this be. I'm lost now. _____ So my hazard lights work perfectly fine, but when I flick the turn signal up or down nothing happens, the interior lights don't flash and makes no 'ticking' sound. It kind of happened out of no where. Are these known to break sometimes? could something have disconnected? The car is a 97, any idea where I could get a 'turn signal switch'? this is what my supra mechanic said I'll likely need. Need to get this fixed, now I look like a kunt cutting across lanes without using the signal. cheers Edited October 18, 2013 by msupra1 (see edit history) Quote Link to comment Share on other sites More sharing options...
Al Massey Posted October 12, 2013 Share Posted October 12, 2013 Isn't the hazards and indicators on different relays and fuse? Quote Link to comment Share on other sites More sharing options...
listy Posted October 12, 2013 Share Posted October 12, 2013 Isn't the hazards and indicators on different relays and fuse? Quote Link to comment Share on other sites More sharing options...
msupra1 Posted October 13, 2013 Author Share Posted October 13, 2013 So this should mean it could just be a fuse? I'm just trying to see what are some things I should check first. Quote Link to comment Share on other sites More sharing options...
Abz Posted October 13, 2013 Share Posted October 13, 2013 Have you disconnected the dash recently?! Disconnecting the dimmer switch will cause this issue as well IIRC. An if you need to change lanes now, used your hazards so then someone can tell something is up and you aren't being a twang Quote Link to comment Share on other sites More sharing options...
Tyson Posted October 13, 2013 Share Posted October 13, 2013 Have you disconnected the dash recently?! Disconnecting the dimmer switch will cause this issue as well IIRC. An if you need to change lanes now, used your hazards so then someone can tell something is up and you aren't being a twang Aren't you supposed to use arm signals when your indicators stop working ? Quote Link to comment Share on other sites More sharing options...
straightsix Posted October 13, 2013 Share Posted October 13, 2013 An if you need to change lanes now, used your hazards so then someone can tell something is up and you aren't being a twang Please don't. It gives no idea of where you're going. Hazard lights should only be used on a stationary vehicle to identify it as a hazard in the position it's in. The only time hazards should be used when moving is under heavy breaking to alert drivers behind of stopped traffic etc. Quote Link to comment Share on other sites More sharing options...
Abz Posted October 13, 2013 Share Posted October 13, 2013 Aren't you supposed to use arm signals when your indicators stop working ? According to the high way code... But his in the states so not sure if this complies with them. Please don't. It gives no idea of where you're going. Hazard lights should only be used on a stationary vehicle to identify it as a hazard in the position it's in. The only time hazards should be used when moving is under heavy breaking to alert drivers behind of stopped traffic etc. Better than just darting across with no warning at all, considering his indicators don't work Quote Link to comment Share on other sites More sharing options...
msupra1 Posted October 18, 2013 Author Share Posted October 18, 2013 So my hazards stopped working tonight, I put the details at the top of the 1st post. Any idea's what it can be if both aren't working? Are these fuses?? Quote Link to comment Share on other sites More sharing options...
straightsix Posted October 18, 2013 Share Posted October 18, 2013 Better than just darting across with no warning at all, considering his indicators don't work No - it's really not. Anyone in this situation should be using the proper hand signals. Quote Link to comment Share on other sites More sharing options...
