hodge Posted October 12, 2013 Share Posted October 12, 2013 I've need doing some work on Kopites car. after a visit to the ring he's boiled his brake fluid and it was like treacle. I've drained the system, flushed and refilled it. Brakes are working perfect now but the ABS light and MIL light are still on. What's the procedure to reset the light. The car is a single turbo facelift with an AEM ECU. Any help would be great. Cheers John Quote Link to comment Share on other sites More sharing options...
bignum Posted October 12, 2013 Share Posted October 12, 2013 That normally means there is a problem with the abs, have you tried ditching the battery for a couple of minutes. Quote Link to comment Share on other sites More sharing options...
Lee P Posted October 12, 2013 Share Posted October 12, 2013 You should be able to do a diagnostic on the ABS ecu the same as the others. Most likely an ABS sensor but the code should tell you Quote Link to comment Share on other sites More sharing options...
hodge Posted October 13, 2013 Author Share Posted October 13, 2013 The engine bay diagnostic port has been removed from the engine bay. I'm i right in thinking the one in the cabin is an ODB2 on a facelift VVTI? Quote Link to comment Share on other sites More sharing options...
wile e coyote Posted October 13, 2013 Share Posted October 13, 2013 Yes mate but there are 2 on mine one works the other is a blank so make sure you use the correct one mate Quote Link to comment Share on other sites More sharing options...
hodge Posted October 13, 2013 Author Share Posted October 13, 2013 Thanks Darren. Top bloke. Quote Link to comment Share on other sites More sharing options...
