power steering fluid
LOGIE
  Axl said:
According to the tsrm app it's dexron 2 fluid and capacity is 1 litre that does sound abit small to me hope this helps :)
Does sound too little. Steering rack alone would prob hold that, then there is the cooler, pipes, pump. Cheers for info on dexron mate.
  SPG said:
Cheers Sunny believe it or not I did try a search but using this site on my galaxy s4 is a pain. So I gave up easily.
  SPG said:
Jesus. 4 litres. More than I thought.
I think its not much more than 1 litre if even than.
When you think about it- The rack is a hollow tube but there is big rod inside it so fluid only occupies the space between.
Similar thing in the pump, there's very little space for the fluid. The reservoir is only supposed to be about half full when you check the level dip stick. The rest is just in the pipe work. :)
