Guest aspire Posted October 8, 2013 Share Posted October 8, 2013 have fitted the R154 box to my jza80 engine, does any one know if the flywheel bolts are the same length as the W58 length? although its all back together now, i didnt measure and fitted the flywheel bolts that came with the conversion. so just need to know if i can order standard bolts? cheers Quote Link to comment Share on other sites More sharing options...
garethr Posted October 8, 2013 Share Posted October 8, 2013 Same part according to the EPC: Soarer 1JZ-GTE / R154 flywheel to crank bolts 90910-02103 (8) Supra 2JZ-GE / W58 flywheel to crank bolts 90910-02103 (8) Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted October 8, 2013 Share Posted October 8, 2013 top man, cheers gareth Quote Link to comment Share on other sites More sharing options...
garethr Posted October 8, 2013 Share Posted October 8, 2013 Check prices. A set of ARP bolts from Whifbitz might be cheaper than a set from Mr T. Quote Link to comment Share on other sites More sharing options...
Guest aspire Posted October 8, 2013 Share Posted October 8, 2013 done £36 for a set, seems silly money Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 8, 2013 Share Posted October 8, 2013 Yes I can also confirm they are the same . . . and they're nearly twice that much from Toyota ! (must be solid gold bolts) If you're buying/fitting a new set, can I scrounge one of your old flywheel bolts?! (I'm doing an engine swap on zero budget, I have 7 bolts, but missing just one) Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted October 10, 2013 Share Posted October 10, 2013 Guess no reply means no then ! Quote Link to comment Share on other sites More sharing options...
