MattP Posted October 7, 2013 Share Posted October 7, 2013 Having issues with the auto box it's a 98 VVTI tiptronic now what I want to do is separate fact from hear say so anybody with credible knowledge feel free to comment Issue one : the car won't engage drive or reverse on occasion and when it finally decides to it has quite a clunk. Issue two : the car pulls well through 3 gears but then just bounces of the limiter in 3rd and refuses to go into fourth in both modes that's manual and standard drive. It will however if you ease your foot off WOT drop into fourth and if you gently press the accelerator to half way slowly build up past 120 leptons as soon as you return to wot it smacks itself back into 3rd and refuses to allow surplus 120 leptons. (The car is fitted with a delimiter chip and mph converter.) Issue three : the box seems adamant on being in 4th as quickly as possible at 20-25mph and struggles to disengage into a lower gear both when braking or climbing a hill and tries to stall out the car Any help? Link to comment Share on other sites More sharing options...
st3ven1 Posted October 7, 2013 Share Posted October 7, 2013 Not a huge amount of help, but issue two is the same for all delimited tiptronics. Just make sure not to suddenly hit WOT at 150+ or it'll change down into third. As far as I'm aware nobody has managed to get around it yet, I also don't think anyone is working on it. As for the other two issues have you changed the gearbox oil and filter recently? Also make sure it's topped up to at least the full level. Link to comment Share on other sites More sharing options...
MattP Posted October 7, 2013 Author Share Posted October 7, 2013 (edited) Yep had the car a month it's been to get checked 3 times at Jm imports had the oils changed etc still no joy jurgen claims the car needs to warn up first I never heard of this problem? Nor did I have this with the past 2 auto supras bar when my box died at 300,000 miles it did the whole I'm not engaging gear routine Edited October 7, 2013 by MattP (see edit history) Link to comment Share on other sites More sharing options...
MattP Posted October 7, 2013 Author Share Posted October 7, 2013 Anyone else ? this cars driving me mad Link to comment Share on other sites More sharing options...
skyline1 Posted October 7, 2013 Share Posted October 7, 2013 I have a tiptronic VVTI delimited and mine doesn't want to gear down to third at mega speeds . Link to comment Share on other sites More sharing options...
Swampy442 Posted October 7, 2013 Share Posted October 7, 2013 Only thing to do is to remove the delimiter and see if things return to normal, is it difficult to do? Dodgy chips are known to cause issues so it may well be the case. Plus you wont be doing 108mph on the road anyway so you wont need it, will you Link to comment Share on other sites More sharing options...
MattP Posted October 7, 2013 Author Share Posted October 7, 2013 No but it's nice to know that if I wanted to I could Link to comment Share on other sites More sharing options...
st3ven1 Posted October 7, 2013 Share Posted October 7, 2013 I have a tiptronic VVTI delimited and mine doesn't want to gear down to third at mega speeds . Are you 100% on this? If you keep accelerating (WOT) to the top of third, does it change up to fourth without backing off? Think(not sure) around 135 would be the top of third. If that is the case you have the only tiptronic I've heard of that works that way and you must have some sort of after market or modified gearbox ECU or a clever delimiter. Would be worth finding out what you have as I'm sure every tiptronic owner would buy one. Even if just for the safety aspect of not risking damage to the engine or auto box. Link to comment Share on other sites More sharing options...
MattP Posted October 7, 2013 Author Share Posted October 7, 2013 Hell I would settle for an autobox that works Link to comment Share on other sites More sharing options...
hodge Posted October 8, 2013 Share Posted October 8, 2013 Yep had the car a month it's been to get checked 3 times at Jm imports had the oils changed etc still no joy jurgen claims the car needs to warn up first I never heard of this problem? Well I certainly wouldn't be pushing a supra past 3k until it's warmed up, or any car for that matter. Your just asking for problems. Link to comment Share on other sites More sharing options...
David P Posted October 8, 2013 Share Posted October 8, 2013 That delimiter is more trouble than it's worth. Poor gear selection when cold could point towards a partially blocked pan filter. Bin the delimiter, fit a new filter, full flush with new fluid and keep your fingers crossed. Link to comment Share on other sites More sharing options...
MattP Posted October 8, 2013 Author Share Posted October 8, 2013 (edited) Well I certainly wouldn't be pushing a supra past 3k until it's warmed up, or any car for that matter. Your just asking for problems. getting in the car on a morning/afternoon putting it into reverse or drive and it just saying nope not today is a heat in the box oil issue? The point is it just won't go into gear I went into the gym last night came out started it up selected drive andddddd nothing selected reverse annnnd nothing sat there repeating steps 1 and 2 for 10 mins then clunk we have drive Does anybody else's tip box do this do you get up in the morning and start the car to go to work and let the car decide when it can be bothered to move The car also gets driven at no more than 40mph as it's a daily from the sticks into Durham center everyday and excess of this speed is simply not possible it's also kept in a fully underfloor heated garage every night so frost etc cold is not an issue Edited October 8, 2013 by MattP (see edit history) Link to comment Share on other sites More sharing options...
MattP Posted October 8, 2013 Author Share Posted October 8, 2013 (edited) I would like to point out as in the other tiptronic thread I am not blaming JM imports for the gearbox issue I am simply looking for other tiptronic box owners experience or lack there of... Of the issues I'm experiencing the main one being having no drive or reverse at times the more information I have the more likely we are to remedy the problem Edited October 8, 2013 by MattP (see edit history) Link to comment Share on other sites More sharing options...
skyline1 Posted October 8, 2013 Share Posted October 8, 2013 Never thought about it to much before , know on the last pull to japfest 2 I got to 140mph ish got off the accelerator then back on it ( to the floor) and didn't gear down of show and sign of wanting to. Is there any way of me finding this out without trying it again? Link to comment Share on other sites More sharing options...
MattP Posted October 8, 2013 Author Share Posted October 8, 2013 Not that I know of Link to comment Share on other sites More sharing options...
st3ven1 Posted October 8, 2013 Share Posted October 8, 2013 Never thought about it to much before , know on the last pull to japfest 2 I got to 140mph ish got off the accelerator then back on it ( to the floor) and didn't gear down of show and sign of wanting to. Is there any way of me finding this out without trying it again? Well an indicated 140 is probably less than 135 actual speed. Speed in each gear for the auto box can be found here: http://mkivsupra.net/vbb/showthread.php?35922-Autobox-gearbox-ratios&highlight=gear+speeds As I thought the top speed in third on a TT Auto box is 135.697mph. What you might find is that if you kept accelerating it wouldn't get any faster without lifting off the throttle and letting it change up into fourth then applying more throttle but not WOT. I searched and read for hours on this subject when I was considering an tiptronic and as far as I can tell there's no way around it. Basically all the tiptronic delimiters do is trick the gearbox into thinking the car is doing less than 120ish at any time hence the danger in kicking down at over 135 as the gear box thinks its doing less than 120. Link to comment Share on other sites More sharing options...
TuneR Posted October 8, 2013 Share Posted October 8, 2013 No issues with mine, what colour is the auto box oil? Link to comment Share on other sites More sharing options...
MattP Posted October 8, 2013 Author Share Posted October 8, 2013 Cherry Red Link to comment Share on other sites More sharing options...
girth45 Posted October 8, 2013 Share Posted October 8, 2013 I have none of these issues with mine, changes gear super smooth, I would do as already said, change auto box filter flush and clean, also disconnect battery re connect and go through the the/auto box learning process. Link to comment Share on other sites More sharing options...
MattP Posted October 8, 2013 Author Share Posted October 8, 2013 will that wipe my Greedy profec spec 2 boost controllers settings? Link to comment Share on other sites More sharing options...
st3ven1 Posted October 8, 2013 Share Posted October 8, 2013 I have none of these issues with mine, I'm willing to put money on it, that you have "issue" two, it's a feature that all tiptronics have once delimited. Unless your car is still limited, in which case it won't go past 112. Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 8, 2013 Share Posted October 8, 2013 will that wipe my Greedy profec spec 2 boost controllers settings? nope it will save it mate - - - Updated - - - I'm willing to put money on it, that you have "issue" two, it's a feature that all tiptronics have once delimited. Unless your car is still limited, in which case it won't go past 112. he is correct Link to comment Share on other sites More sharing options...
wile e coyote Posted October 8, 2013 Share Posted October 8, 2013 Yes the tiptronics gearbox ecu is built in with the engine ecu and can't be sorted yet I use a speedm8 converter but don't think you can get them anymore I've also bumped an old thread on this for you in technical Link to comment Share on other sites More sharing options...
Jurgen-Jm-Imports Posted October 8, 2013 Share Posted October 8, 2013 Yes the tiptronics gearbox ecu is built in with the engine ecu and can't be sorted yet I use a speedm8 converter but don't think you can get them anymore I've also bumped an old thread on this for you in technical we use speedm8 on all our cars Link to comment Share on other sites More sharing options...
Guest Lee_89 Posted October 9, 2013 Share Posted October 9, 2013 Mine is a 98 trip full bpu sourced by JM imports, soon as I start it I can select gear straight away, I keep revs below 3k for the first 10 minutes before pushing any harder, but I have no issues in the higher territory Link to comment Share on other sites More sharing options...
