LOGIE Posted October 6, 2013 Share Posted October 6, 2013 Is it possible to change these without removing the turbos and inlets, the reason im thinking of changing is the engine has the facelift weaker ones fitted and I have a set of the older stronger ones lying in the garage. Cheers Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 6, 2013 Share Posted October 6, 2013 (edited) Intake Side- Remove the oil filter Housing from the block. 1 Big nut and two water pipes with clips. Exhaust- Remove downpipe/cat, then the collector section above that(3 more nuts). Then it's just 4x 14mm bolts each side. Defo do it now whilst it's not in the car...!! Much easier. You'll need 1x shorter bolt each side, as the facelift ones use a longer bolt in one hole due to the shape. Edited October 6, 2013 by TheTurtleshead (see edit history) Quote Link to comment Share on other sites More sharing options...
LOGIE Posted October 6, 2013 Author Share Posted October 6, 2013 Intake Side- Remove the oil filter Housing from the block. 1 Big nut and two water pipes with clips. Exhaust- Remove downpipe/cat, then the collector section above that(3 more nuts). Then it's just 4x 14mm bolts each side. Defo do it now whilst it's not in the car...!! Much easier. You'll need 1x shorter bolt each side, as the facelift ones use a longer bolt in one hole due to the shape.Thanks for that mate, is there a gasket that needs replacing on the collector section once it needs to go back on?? I have the original bolts from the pre facelift brackets. Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted October 6, 2013 Share Posted October 6, 2013 Nah the gaskets will go again if they're in good condition. Quote Link to comment Share on other sites More sharing options...
LOGIE Posted October 6, 2013 Author Share Posted October 6, 2013 Nah the gaskets will go again if they're in good condition. Jubly. thanks matey much appreciated. Quote Link to comment Share on other sites More sharing options...
