alternator problems n/a 93 auto
Dave
my alternator stopped working all my dash lights were on ,so removed it and cleaned it up ,now all the lights go out but im not getting a charge ,is this still the alternator or do i have another problem ie : main fuse etc???
thanks in advance for your help ---dave
Guest Roger NE
Best advice is to buy yourself a cheap Multimeter - essential for diagnosing all kinds of electrical problems, not only on your car!
I'd suggest buying an Analogue one, as you can see changes in readings much more readily, and you also get less false readings compared to a digital display type.
Then measure the voltage across the battery, and see how it changes when you run the engine, and also when you increase the revs
In the meantime, turn the headlights on . . . if the Alternator is working you should notice an increase in brightness between tickover and increasing the revs to about 2000 rpm.
thanks roger have got a multimeter but no idea how to use it ,did the lights test and no increase in brightness ,going tomorrow to see if i can get it refurbed,thanks for your help ---dave
