Range Rover restoration
Dnk
Both rear quarter windows and old dried out seals were removed, i then unbolted
the rear seat belt mechanisms so i could remove the interior corner trims which
then gives you access to the nuts that hold the exterior corner trims that are covered
in vinyl.
This is in readiness for the shell to be painted, driver side was nigh on perfect but
the near side has more rot that needs to be removed.
Started rubbing down the panels with red scotch brite too
It's scary where you find it on an old Range Rover, didn't expect to see any in the rear top corners, it's fixed
now and has been cut out and a plate welded in, the battery tray also got welded in and more scotch brighting.
Had a large bag of 3M stuff arrive, seam sealer and stone chip, supposedly the best you can buy
Been all over the chassis and it's solid apart from one small patch which is next to one of the cats.
I've been reading up on Galvanizing and it appears to be rather tricky to paint it so i don't know
what to do now, maybe acid dip then wax oil the inside and paint the outside
Its going to get dipped now, thanks for nagging me Chris :)
I've found a flexible rubber paint that is supposed to stick like **** to a blanket so we'll
give that a try. Don't really want to powder coat it to be honest but according to the info
i've read p/c sticks quite well to zinc.
I have bigger issues now as what looked like minor easy fixable corrosion is way worse, along the seam
in the engine bay where the front of the scuttle panel joins the bulkhead. The top piece has corroded around
the spot welds and has got to be cut out
I'm in way to far to chop it up, the budget went out the window ages ago so i just have to bite
the bullet and finish it. Maybe in 10 years time i might break even if they continue to rise in value
and more of them turn to rust heaps.
I keep saying its only money and whats a few more £x's i have to spend in the great scheme
of things, i think the next stop is a padded cell.
Off to the pub very shortly to drown my sorrows with a couple of pints of Tribute
Before i hit the pub i popped into the workshop and decided with Phil we had to pull
the whole dash out including all the wiring loom, heater box and sound proofing.
By 17:30 the dash, heater box & loom was out, i took lots of photos to help us
put it back together, now we can repair the bulkhead and the front scuttle panel.
I'll pop some photos up tomorrow as i left the camera in the car
I'm not down just a bit peeved as it didn't look that bad, to be honest it's actually
not that bad but to fix it all the dash etc had to come out which we could
of done without.
I'll have a look through that when i get in later
Having got all the dash out i'm glad we did as it's a joke how it's been fitted
with wires shoved in any old how, masking tape, bolts not done up etc etc, it
will go back in far better than it did on the assembly line.
Bulkhead is getting there and another day should see it finished.
Took the seriously grubby front carpet home and jet washed it with my new
K4 Karcher jetwash, went over budget buying that as well lol
Chassis is stripped, i'll be taking it to get it's acid bath then galvanized tomorrow.
A few more bits are heading off to the shot blasters, air tank, engine and gearbox
mounts and the box where all the air suspension valves etc live
The bulkhead is now fixed and free of rot, i've also had an idea on how to stop this happening
in the future so the upper bulkhead is going to be modified slightly so it can't fill up with water
again.
Coming along very well now! But you should have bought that recovery truck instead of the RR, it looks a minter ;)
What sort of job is re-stuffing the dash going to be? I can just imagine the attempts the workers of the period would have made to short cut (and probably short circuit) the wiring and heater etcetera, that's fortunately, for them, out of sight.
Very nice build, please keep posting the photos!
