Range Rover restoration
Dnk
Have you considered a full shell strip and having it dipped? Or should that be dunked? :) I have seen some very impressive results by chemical stripping and then immersion phosphating, and it is cost effective.
Yes Chris i had thought about it but then your into doing a 100% restoration and the costs
start going a little silly, with the rot we've found i'm quite happy it doesn't need this.
There is a brand new chassis and shell in the workshop for Phils next project once mines out
the way.
Boot floor is now out and i'm pleased to say the chassis is in great condition, only very light
surface corrosion, just needs a good clean and a fresh coat of paint.
The only place on the chassis that needs more attention is next to the nearside down pipe where the cat
sits next to the chassis, the corrosion there is a lot heavier but once the exhaust is off it should
be pretty easy to cut out the rot and weld in a new piece.
The finished 2 door with a 4.6 in it, a 4.2 LSE Overfinch and a new body waiting to be built that's going
on the new chassis
I've been locating some of the interior trim parts i need, on the door casings
there are whats called finger pulls as you can see in the photo.
All mine are cracked or got a part of the edge missing, i trawled ebay for a while
and found a guy selling 3 of them in perfect condition for £30 and nearly hit the
buy button.
Another place wanted £20 each for them !!
I gave LR a call for a giggle and would you believe it they can still supply them, i
have 4 new ones coming on Wednesday, £4 each + vat
Another item crossed off my list :)
Rear cross member is out along with the rear axle, petrol tank etc
Really happy with the condition of everything so far and only surface corrosion on
chassis which i'm really pleased to see.
The diff oil was drained and just nice clean oil came out, no signs of anything nasty, it'll
get cleaned up, painted then refilled with fresh oil along with new discs, calipers, airbags
and brake lines.
Once the rear cross member is in the back end of the chassis will be cleaned up and
painted and the axle can go back in
The balance weight has come off the rear propshaft so i'm just searching for somewhere
local to do that
Rear axle has been stripped cleaned and painted, just awaiting new parts to get rebuilt.
Front axle is also off the car, it's been jetwashed and now being stripped, new swivel
housings are on order as the old ones are scrap, got some Teflon coated ones coming.
It should be rust free and painted ready to be re built by the end of the day.
Again nice clean diff oil has come out of it and the half shaft splines look in
very good condition
Thanks guys, got a lot of parts to media blast now to remove surface rust, then some bits will
be powder coated and others painted with chassis paint, the same stuff going on the axles.
Not sorted the paint for the exhaust yet and also have the rocker covers and plenum to do
but they can be done later.
Spoke to soon regarding the front diff as it needs a re build and one cv joint is scrap
but i'll replace both of them.
Looks like it had a problem and someone just did an oil change hoping it would fix it.
The drive shafts are fine though so that's good news
Had a good result down at the shot blasters though and their doing a large pile of stuff
for a very sensible amount of cash :)
The rear axle case will get done as well as the pile in the photo along with the Y piece
and manifolds
Collected the first batch of parts from the shot blasters this morning and dropped off the
rear axle case along with the manifolds and exhaust Y piece .
Had 2 studs in the drivers side cylinder head break but when the inner wing is removed
there should be enough room to carefully drill them out, fingers crossed :)
Have also spoke to a good mate of mine about re skinning the lower tailgate, i shall be
dropping that off at his workshop tomorrow for him to have a look.
I'm contemplating replacing the steel skin with aluminium
A few parts i collected yesterday from the shot blasters which will be painted
this afternoon.
Clean and paint the front axle then rebuild with new diff, cv's and swivel
housings.
The rusty Y piece is at the blasters so we'll see what state that is in
tomorrow
Looking good! Are you painting or powder coating? Do you mind me asking how much you are paying for blasting? My local place are more into very coarse work and the finish is very rough, they aren't keen changing abrasives to something finer unless I send them a LOT of stuff to do in one hit. Cheers!
Change of plan today, body is coming off the chassis once the rear cross member, sills and front end panels
are welded in, the chassis is then off to be chemically stripped inside and out followed by being galvanized.
