Range Rover restoration
Dnk
Would the aqua blasting have not been enough on its own?
Wasn't doing a fat lot according to my mate so he masked up the threads and media blasted them.
My issue now is unless all the info i've found on the spigot bore size is wrong these wont fit, put one
on the CMM and that's saying the spigot bore in the spacer is 113.342 but the hub is 114.3, going to
see if it fits this afternoon
The spacers fitted perfectly in the counter bore of the wheel and on the
spigot hub, we replaced the hex head drive flange bolts for cap heads
and fitted the wheels.
Very happy with it now and no need to reduce the thickness which surprised
me a little.
Test drove it and drives great for an old bus :)
Also fitted a new set of Tuff-Rock mud flaps
  • 1 month later...
Got to love classics especially Land Rovers.
Got an issue with the air suspension, it will only let me use the highest setting, also the SRS warning light has decided to come
on in sympathy with height setting warning light. Time to plug it in and see what's up.
Fixed the SRS by swapping out the rotary coupler last time so we'll see
  • 4 weeks later...
Bought 2 new EAS circuit relays to try, also found a soft dash being broken locally that was working fine before its
crash so got a spare EAS ECU and an EAS delay relay that you can't buy anymore.
Just been out in the drizzle, swapped the relays 1 at a time and nothing :think: beginning
to think the compressor could have died
Plugged it into the Lynx diagnostic tool and its flagged up a problem with the OSF height sensor.
Luckily i have a spare set so changed that cleared the fault and yay its working again.
Going to future proof the system and overhaul the EAS valve block which you can buy a
seal kit for, fit a new dryer and either overhaul the compressor or fit a new one.
Also looking into fitting new height sensors from the P38 which you can fit with a wiring mod
  • 1 month later...
Touch wood all working 100%. The heated screen is also working nicely and cleared in 3 mins
The SRS light has also decided to have a rest after being reset :)
Was a good test for the TRC and ABS in the snow the other day, the Michelin Pilot Sport SUV'S
worked well enough too and coped easily with a couple of hills
  • 3 weeks later...
On 1/26/2021 at 4:56 PM, Frank Bullitt said:
Looking good, how was the 4x4 action?
Not sure if you noticed but you have a photo up with the KY on your dash, luckily no Lemsip could be seen 😇
Only wanted to try it out on the new Michelins and was fine, didn't go far and break the distance from home rules.
Thats a bottle of sanitizer lol
  • 2 weeks later...
Passed its MOT yesterday and no advisories.
I have to buy a new Y piece down pipe though as the cats are on their way out. I can buy genuine LR
but at £4100🙄 think I'll pass on that
Spoke to a local performance exhaust place and they will make me
a st/st system from the manifolds back for £1500 + vat with lifetime warranty
I've found an aftermarket downpipe for £300, it has 3 year warranty and says its euro 1 and 2 on the emissions
so I'm going to see what that's like before i have a custom job made
An ex F1 guy is making exhausts for Kingsley cars who restore Range Rovers £3450 + vat but a full system.
Some of the welds don't look that great to me ? https://www.kingsleycars.co.uk/range-rover-classic-exhaust-system/#&gid=1&pid=1
6 minutes ago, Annabella said:
Fast! Good luck, are you fitting it?
It'll go on a ramp at my mates garage and we will do some other jobs at the same time
Fit new modified bump stops, replace a breather hose on the fuel tank and fit a new dryer for the EAS
  • 2 weeks later...
The catalytic converter downpipe arrived quickly but sadly it was just a very cheap BM Catalysts one.
I've found them on ebay for £99 so god knows what the cats are in them
I've sent it back and waiting for a refund
Got my refund so back searching for a better cat pipe but it all looks cheap and not
worth bothering with.
Going to pay the performance exhaust shop a visit and see what their work looks like
  • 2 weeks later...
Found new OE height sensors for the EAS so plashed out some more cash
Sadly my mate who owns the garage has had to self isolate, his son caught covid
at school so going to be the end of March before we get it on the ramp
