Range Rover restoration
Dnk
Fantastic attention to detail, must be getting close to finished now
Still got to find a paint shop but i'm in no rush to do that as the original paint isn't too bad
Need to sort out a new top tailgate, thought i'd found a good genuine one but the seller wanted silly
money for it.
  • 2 weeks later...
Still having trouble getting the screen sorted but now there is another issue, the passenger side
heated element doesn't work. We had our first cold night yesterday and the Range was frozen over
so a perfect test.
The circuit is very simple with one switch, one relay which then splits into two with
two inline fuses before it connects to the screen
Checked the fuse and that's fine and there's power to it so my guess is the new screen is at fault
Gain access to both wires going to the embedded trace in the left side of the screen and check the resistance of the trace itself. It should be very low, under 5 Ohms (if it was 5 Ohms that's only a 2.6 Amp current draw at 13 volts). These things draw hefty currents, a lot more than 2.6 Amps and any poor grounds or connections with highish resistance will stop them working either at all, or properly. Knowing BL's standard of wiring and connector quality I wouldn't condemn the screen quite yet, although they aren't the most reliable of things.
This link may ultimately assist ;) :
http://www.ebay.co.uk/itm/12x-Carplan-Blue-Star-DE-ICER-300ml-Aerosol-Spray-Can-Fast-Melt-deicer-ice-/321232642139?hash=item4acaf5205b:g:BdAAAOxyOypSZN99
Edited by Chris Wilson (see edit history)
Admiral want the checks done by the restoration company so i'm just organising that now, hopefully get it in next week. It looks like the screens
got to come out anyway as two of the new trims aren't right and looks like the screen could actually be set off centre and too high according to the boss at the restoration company.
I might give up with Admiral at this rate and get it sorted myself, its only been going on since Aug 17th, i've emailed Pilkington Glass for a price on a new screen and also getting in touch with one of their approved installers
For now i've been fiddling with the head unit, i was worried that when i took the modern Pioneer cd player out i'd find all the original plugs had been cut off or butchered, happy days though as they're all still there
I just need to get the original Clarion unit sent off to http://www.clarion-service.co.uk/cs/Home.html to get it fully refurbished and make it iphone mp3 compatible etc £99.99 inc vat :)
  • 3 weeks later...
Thanks to Michael i have the head unit working, more good news the amp and sub both appear to work as well :)
I had the RR in the restoration companies workshop to inspect the windscreen to see why half of it didn't heat up
and how well it had been fitted.
To do this the bonnet and deck panel have to come off.
There are two pegs on the RR's frame that the screen sits on along its bottom edge, one side the screen is sitting off the peg by approx 2-3mm
and around 5-6mm on the other.
The trims on the A posts are held down to the pillar with double side tape, the fitters haven't removed the protective film off the tape on either side.
The reason the passenger side didn't heat up is because the plug they connected to the Range Rovers wiring had fell apart but they didn't notice this but i can't say i'm surpised.
If your around B'ham don't use Turbo windscreens, they are a bunch of useless clowns
Afraid the head unit looks like it has a fault, one minute it works the next it doesn't, checked the feeds to it and
all seems as it should be.
I've tried wriggling the plugs around on the back of the unit but nothing seems to affect it.
Tried the other head unit i have but that doesn't do anything.
Looks like i'll have to send it off to Clarion after all :(
We had a nice frost this morning so i thought i'd go and do a proper test of the heated
windscreen, low and behold it now works.
Hopefully we can get it out in one piece so it can be re fitted properly now i know for sure
this screen works as it should
Dunk, this is a credit to you mate. I don't pop on the forum much these days but it makes the visit worthwhile when there are top quality projects like yours to check out :-)
This reminds me of my old MY93 3.9SE in Aspen Silver; lovely car.
Thanks Andrew, hopefully i'll have it finished one day :) Aspen Silver is a lovely colour
on a classic :thumbs:
I'm hearing rumors that LR Heritage are going to be remaking some parts no longer
available such as the door cap rubbers and the rubbing strips.
That would be nice if they do as i'd be replacing all mine then when it gets painted.
Still unsure about fitting the genuine Brooklands kit, i have new genuine corner bumpers
and was contemplating chroming the original bumpers, hmmm
I do like the Brooklands Vogue Dunk but I think I prefer the Facelift version of the Classic Vogue, I.e. The big bumpers.
The Aspen Silver paint scheme is probably the nicest colour on any car I've owned. It was fantastic mate.
Really loving your thread - now get some more pics up, lol :-)
Sorry Andrew, not got really anything new to take photos of :)
I've just had an email from my insurer and they now agree that Nationwide screwed
up when they fitted the screen and i can go ahead and get it sorted at a place of my choosing.
They'll cover all the costs including using genuine trims and pay for the investigation done
by the restoration specialist
They've put £100 on top as compensation for my inconvenience :) just under £700 in total
Being cynical i hope my next premium doesn't dramatically increase :rolleyes:
  • 4 weeks later...
Sent both head units to the Clarion service center and not that impressed so far to be honest.
Poor comms from them, they've had them since the 17th Jan, i chased them up and they say one unit
is beyond saving and they are looking at the other ? That was on Jan 30th
Not heard anything from the Clarion service center so i just called to find out whats
going on, they can't fix the other head unit either as it has damage to the PCB, they told me
about the damage 10 days ago but didn't say they couldn't fix it. ffs !
What a waste of time that was, i shall give gb4x4radios a call and see if they can do repairs to circuit boards
If you can e-mail me some high res photos of the board damage I can tell you if I might be able to fix it, I have repaired some fairly poxy PCB's before now.
Cheers Chris, as soon as i get them back i'll open them up and have a look
Still waiting to get the head units back, not impressed now, so much for the next day return they offer on the website
Just spoke to them and the person who answers the phone hasn't got a clue, going to call me back, ****ing useless !!!
Took the Range for its 3 rd mot since the re build and all good.
The head units are back, i took the top covers off but without totally stripping them it's very hard to
photo the pcbs, looks a lot more involved than i'd thought they'd be and can see me getting in a right mess
if i started :)
I think i'll send the one to http://www.gb4x4radios.com/ and see what they can do
  • 1 year later...
