Range Rover restoration
Dnk
The speaker grills are looking tired so i shall sand blast them and then im thinking of spraying
with the plasti dip stuff.
I'm not sure if it'll fill up the fine mesh too much though ?
Anyone used this on bare metal ?
Speaker grills are done, rear door cards are off awaiting G101 treatment, i also used it
to help get this off the dash that was seriously stuck to it.
Gave the engine bay a bit of a clean up to get my agreed value photo as well :)
Cleaned up the scuttle panel air vents and re fitted them with new filter mesh, doing
the front grill and sorting the bonnet out next.
The rear door cards i'll attack next week, i can finish all the vinyl once its clean now as
the Poorboys natural look Interior dressing arrived yesterday :)
One set back i have to strip the rear doors as the steel window frames are rotting inside
the door.
I can get a new offside from Land Rover but £200 + vat :blink: not sure how i'm going to fix
the nearside unless i can find a good second hand one !
But you know a man who is, on your knees, hands together :)
Or for none believers there's always *FLASH* ;)
Afraid i'm a non believer and my little digi camera isn't that great
Stripped the rear doors down and both frames are borderline, after a bit of
searching i've found new replacements for both sides and got both for what one
would of cost from Land Rover, they were only a 30 minute drive away so got them
yesterday :)
The new window seals and support pieces arrived from LR as well :)
It's far from finished Chris :rolleyes:
I found this rot when i took the rear door cards off to clean them so it had to be
dealt with.
I have to do something with the wood trim as that's faded but i'm still not to sure
what to do with that, i quite fancy doing it in Piano Black, also have to paint both
sides and possibly the roof if i want it 100% right.
I've just had my agreed value come through from Admiral and i'm very happy with the
outcome, no restrictions on use and will be reviewed once i've got it painted
£337 fully comp and agreed value of £30k :)
Time to crack on and get it finished
  • 2 weeks later...
Assumption is the mother of all fuck ups.
I know i should of checked before so why didn't i, i'm putting it down to age lol
Edited as i've been given wrongly labelled bolts
UNF are the door frame threads not BSF, the threads that
hold the door handle brackets and other bits on are 6 mm
just to add to the fun
That sounds more like, BSF is ancient stuff. But nothing BL or whatever they were called back then did would surpise me :) Coming along well, any other horrors likely to be found?
I have to find somewhere to paint it now but i'm leaving that till next
year.
I just have to re assemble the door cards and fit them, find a new head unit
and sort the wood trim pieces out.
No more horrors hiding as far as i can see.
Bonnet catch and safety hook are now fitted
