Axl Posted October 3, 2013 Share Posted October 3, 2013 Hi everyone my na manual has shocking fuel consumption it uses the same as my mates tt with bpu I'm gonna clean the O2 sensors as I've read that this helps but I woz wondering would it help to put a cleaner through it as well? Has anyone tried this? Any thoughts would be much appreciated thanks Quote Link to comment Share on other sites More sharing options...
MattP Posted October 3, 2013 Share Posted October 3, 2013 I also tried the above cleaning the O2 sensors and various injector cleaners etc etc and my n/a was a pig my brothers bpu twin is strangely frugal in comparison Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 3, 2013 Share Posted October 3, 2013 Check all your brakes incase they're begining to seize up, also check tyre pressures Quote Link to comment Share on other sites More sharing options...
MattP Posted October 3, 2013 Share Posted October 3, 2013 ^ I also refurbished all 4 j-spec calipers pistons chris Wilson seals etc and fitted braided good ridge lines it had no effect on fuel economy I would say n/a supras are not as good as there TT counterparts if driven easy in fact there is a thread on here that states as much but ofcourse at wot the TT will be worse... I did have a issue with my mr2 brakes binding so replaced all of them which made a huge difference to fuel economy remember these cars are clocking on now and should really be having allot of major parts replaced or checked Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 3, 2013 Share Posted October 3, 2013 (edited) Well its worth checking as most that aren't rebuilt by now are on the verge of failing if not already. Easy enough to check just like tyre pressures, i like to start with the easy fix first, just hold the back of your hand close to the wheel near each caliper without touching it and see if any are hotter than the others I've never had an NA but my BPU TT if i drove fairly sensibly was great on fuel and do 25 mpg no problem. If i really drove in fuel saving mode it would do 30 mpg but not with flat tyres or sticking calipers which i suffered once when a rear seized. Edited October 3, 2013 by Dnk (see edit history) Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 3, 2013 Share Posted October 3, 2013 Hi everyone my na manual has shocking fuel consumption it uses the same as my mates tt with bpu I'm gonna clean the O2 sensors as I've read that this helps but I woz wondering would it help to put a cleaner through it as well? Has anyone tried this? Any thoughts would be much appreciated thanks To be honest mate when driving normally the TT dosent use much more fuel then the NA it's only when you start to give it what it's got its starts draining the tank. It's like I said when we went on a family holiday and drove across France my dads 2.2 omega used 3 tanks of fuel driving at 90-100mph and my TT used 3.5 tanks driving at 120-130mph as I didn't notice the posted limit was in kilometres . That was also giving a few hard pulls against an R6 crotch rocket which was a lot of fun but that's another story Quote Link to comment Share on other sites More sharing options...
Bossco Posted October 3, 2013 Share Posted October 3, 2013 So............is fuel injector cleaner anygood? Quote Link to comment Share on other sites More sharing options...
dan294 Posted October 3, 2013 Share Posted October 3, 2013 Millers Eco Max is pretty good. Boosts octane too. Use it in my BM. Cataclean is also worth a look. Tried that in every car I've had recently. Worked well in the BM and my Escort. Made noticeable mpg differences in both. Quote Link to comment Share on other sites More sharing options...
_Shane_ Posted October 4, 2013 Share Posted October 4, 2013 some of them fuel cleaners on the market are actually good, saw an episode of wheeler dealers recently and they added some to a vw corrado and did a before and after dyno run (a week after the fuel cleaner was added to a full tank) and they saw an increase of 8bhp iirc Imo if it genuinely works then spending a few quid on a bottle of this is surely worth it Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 4, 2013 Share Posted October 4, 2013 I'd send them to CW and get them flow tested and cleaned Quote Link to comment Share on other sites More sharing options...
ManwithSupra Posted October 4, 2013 Share Posted October 4, 2013 I'd send them to CW and get them flow tested and cleaned Yeah whip them off and send to Chris Quote Link to comment Share on other sites More sharing options...
Axl Posted October 4, 2013 Author Share Posted October 4, 2013 Thanks for the advice guys how much does Chris charge? Quote Link to comment Share on other sites More sharing options...
imi Posted October 4, 2013 Share Posted October 4, 2013 I believe the market rates are roughly 50-70 per injector. Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 4, 2013 Share Posted October 4, 2013 Thanks for the advice guys how much does Chris charge? I have his number if you want it mate Quote Link to comment Share on other sites More sharing options...
Axl Posted October 4, 2013 Author Share Posted October 4, 2013 I have his number if you want it mate Send it to me cheers mate Quote Link to comment Share on other sites More sharing options...
ScottC Posted October 4, 2013 Share Posted October 4, 2013 Can you replace the filters on stock injectors? Quote Link to comment Share on other sites More sharing options...
fastcar Posted October 4, 2013 Share Posted October 4, 2013 Can you replace the filters on stock injectors? There is an inline fuel filter on the fuel line if that's what you mean Quote Link to comment Share on other sites More sharing options...
ScottC Posted October 4, 2013 Share Posted October 4, 2013 There is an inline fuel filter on the fuel line if that's what you mean I thought there might be a filter in the injector. I guess not Quote Link to comment Share on other sites More sharing options...
Ian C Posted October 4, 2013 Share Posted October 4, 2013 I believe the market rates are roughly 50-70 per injector. Surely not? May as well buy new ones at that rate? Quote Link to comment Share on other sites More sharing options...
Dnk Posted October 4, 2013 Share Posted October 4, 2013 £12.50 each for petrol injectors at injector tune inc testing http://www.injectortune.co.uk Quote Link to comment Share on other sites More sharing options...
imi Posted October 5, 2013 Share Posted October 5, 2013 £12.50 each for petrol injectors at injector tune inc testing http://www.injectortune.co.uk No brained then Quote Link to comment Share on other sites More sharing options...
