Abz Posted October 6, 2013 Share Posted October 6, 2013 Anyone? Think it might be the thread title putting people off clicking on the thread, it's not exactly very clear Link to comment Share on other sites More sharing options...
Rich.2211 Posted October 6, 2013 Share Posted October 6, 2013 You can edit the thread title by editing the post and clicking on advanced. Link to comment Share on other sites More sharing options...
LOGIE Posted October 6, 2013 Share Posted October 6, 2013 check your timing belt it may be snapped Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 6, 2013 Share Posted October 6, 2013 Timing belt Is fine first thing I checked Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 6, 2013 Share Posted October 6, 2013 Think it might be the thread title putting people off clicking on the thread, it's not exactly very clear Changed Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 7, 2013 Share Posted October 7, 2013 (edited) Oh look at all the replies flooding in now I have changed the titie Edited October 8, 2013 by suprageek (see edit history) Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 8, 2013 Share Posted October 8, 2013 still no joy with this Link to comment Share on other sites More sharing options...
girth45 Posted October 8, 2013 Share Posted October 8, 2013 Hi don't know if i can help, but will try having read your thread, you have fuel pressure but no spark, Did this happen out of the blue, or had you been working or changing things on your car? Crank sensor would be the next place I would look, Does the car sound normal when cranking ? Check ECU connections and earth pionts. Link to comment Share on other sites More sharing options...
mellonman Posted October 8, 2013 Share Posted October 8, 2013 Have you thought about it being the alarm immobiliser? Maybe check the power to and from the igniter there is a repair manual on the front page that might help Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 8, 2013 Share Posted October 8, 2013 Hi don't know if i can help, but will try having read your thread, you have fuel pressure but no spark, Did this happen out of the blue, or had you been working or changing things on your car? Crank sensor would be the next place I would look, Does the car sound normal when cranking ? Check ECU connections and earth pionts. hi just happened out of the blue i was driving the car on the motorway and it cut out, when its cranking sounds normal has a real strong crank, i have a crank position sensor arriving tomorrow from rob mitchell, i will check the ecu connections and earth points tomorrow, thanks i appreciate your reply dave - - - Updated - - - Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 8, 2013 Share Posted October 8, 2013 Have you thought about it being the alarm immobiliser? Maybe check the power to and from the igniter there is a repair manual on the front page that might help never thought of the immobiliser, i will check the power to the igniter too, thanks mellonman! Link to comment Share on other sites More sharing options...
np89 Posted October 8, 2013 Share Posted October 8, 2013 You asked Colin at SSI mate? He could prob solve it over the phone for ya! Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 8, 2013 Share Posted October 8, 2013 i talked to marty at ssi through facebook, ill ring colin tomorrow thanks niall! Link to comment Share on other sites More sharing options...
np89 Posted October 8, 2013 Share Posted October 8, 2013 no probs bud Link to comment Share on other sites More sharing options...
jim Posted October 11, 2013 Share Posted October 11, 2013 Did you get sorted David? Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 11, 2013 Share Posted October 11, 2013 Just got the crank sensor in and I now have spark and I changed the plugs it's still trying to start but dosnt def better than before, here's a pic of the crank sensor I took out Why is it dented? Link to comment Share on other sites More sharing options...
mellonman Posted October 11, 2013 Share Posted October 11, 2013 now im not sure where abouts the crank sensor is but thought it wa by the timing star near the crank pully, for that to be dented is odd to me unless the crank moved or timing star to be loose, i would investigate the timing star is still attached to the belt cog, (if thats where its situated), and if its no longer attached it would put your timming out so wont start, but if its further into the block i would do a compresson test to make sure everything is where its ment to be, Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 11, 2013 Share Posted October 11, 2013 Seen this http://www.supraforums.com/forum/showthread.php?546577-Crank-Sensor-Question-Car-Died Think I've found my problem Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 11, 2013 Share Posted October 11, 2013 Yes mellonman apparanty the trigger wheel can come off knocking the timing off 30 degrees that would explain the dent as the sensor sits just on the left of he crank, will get a look on monday Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 11, 2013 Share Posted October 11, 2013 Link to comment Share on other sites More sharing options...
Guest suprageek Posted October 14, 2013 Share Posted October 14, 2013 Got the crank case open and the star/trigger wheel was spinning freely found the prob so will have it welded onto the crank pulley wheel and that should be job done! Link to comment Share on other sites More sharing options...
supra joe Posted October 22, 2018 Share Posted October 22, 2018 Just bumping this to look back on. Having the same issue. Crank and no spark. Link to comment Share on other sites More sharing options...
