GetawayDriver Posted March 12, 2003 Share Posted March 12, 2003 I have a weird noise coming from the the right hand side of the engine bay. When i turn the engine off it contines for 5-10 seconds after the engine has stopped. It not a screech or whine as in the famous death rattle sound clips on MKIV.com. It's more of a spinning vibration, like one of the Turbos has excessive play in the shaft and is vibrating at a certan RPM on spin down. It starts of quiet, reaches a peak which is not very loud, you have to concentrate to hear it and then the pitch climbs as it slows down and the volume drops off. At full boost there is no noise, or maybe i just can't hear it. The car has 105k miles on it, UK Spec, Stock Turbos and Boost... I'm guessing i've discovered the life expectancy of a stock uk Turbo. Anyone got any thoughts? Seen it before? please... some one disagree with me and tell me it's unbalanced radiatior fan!!! Quote Link to comment Share on other sites More sharing options...
Nathan Posted March 12, 2003 Share Posted March 12, 2003 Personally I think it's unlikely to be compressor to housing contact if you can't hear it while you are under boost. Still, worth checking anyway. I'd pull the inlet pipes off and check play with your fingers. Not a big job. Sorry, can't be any more helpful without hearing it myself. Regards, Nathan TDI PLC Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 12, 2003 Share Posted March 12, 2003 Does it sound like a frog ? Quote Link to comment Share on other sites More sharing options...
ghosty Posted March 12, 2003 Share Posted March 12, 2003 Originally posted by Nathan Still, worth checking anyway. I'd pull the inlet pipes off and check play with your fingers. Not a big job. TDI PLC When the engine is cool obviously! Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted March 12, 2003 Author Share Posted March 12, 2003 not like a frog really..., but then again my experience of frogs is limited. it just sounds like a very tired turbo i think. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 12, 2003 Share Posted March 12, 2003 From that i take it that you have more experience with tired turbo's It's just the problem your describing is one that is similar to a frequent one where the reed valve gets a little lazy and can make a noise when you turn the engine off and air escapes past it. It is repairable but not a big issue AFAIK. I'll try to see if i can dig up the relevant info. Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted March 12, 2003 Author Share Posted March 12, 2003 please do.. any info would be great help, although i was getting excited about a pair of hybrids! Quote Link to comment Share on other sites More sharing options...
womble Posted March 12, 2003 Share Posted March 12, 2003 If it does turn out you've discovered the life expectancy of uk turbos at 105k then it'd seem I was robbed of 6k !!. Quote Link to comment Share on other sites More sharing options...
Branners Posted March 12, 2003 Share Posted March 12, 2003 My Uk turbos are at 118,000 and still going strong at 1.2bar (but it has only been 1.2 bar for 2,000 miles) JB Quote Link to comment Share on other sites More sharing options...
Jez sutherland Posted March 12, 2003 Share Posted March 12, 2003 My UK spec turbos are going well at 105,000. You never know though! Jeremy Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted March 13, 2003 Author Share Posted March 13, 2003 Okay, it's not my turbos, thank god, i had a fish arround under the bonnet and the noise seems to be coming from the big black box just after my airfilter in my HKS induction kit. I guess this is an air flow meter or something? and... yes after watching some animal planet last night, it does sound a bit like a frog, but a really big one, made of black plastic and looking expensive. Anyone had this problem before? is it the same reed valve one you mentioned Martin F? Anyone know how to fix it? Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 13, 2003 Share Posted March 13, 2003 Well i couldn't find anything that i had saved in my emails at home, but i know i've heard of this problem before and my own car does it on occasion. I've just found this on Supraforums :- http://www.supraforums.com/showthread.php?s=&threadid=637&highlight=Reed I don't know if it is actually anything to worry about. Maybe somebody who is more familiar with the sequential system can shine some light. Quote Link to comment Share on other sites More sharing options...
GetawayDriver Posted March 13, 2003 Author Share Posted March 13, 2003 cheers for the link, thats sounds pretty close to what i have. i have no power loss, it's just sounds stupid. thanks for all the help guys, i'll let you know how it goes. Quote Link to comment Share on other sites More sharing options...
