jumpbike Posted September 25, 2013 Share Posted September 25, 2013 I've searched around but maybe I'm not wording it right, basically, can the first butterfly (stepper motor controlled one) simply be unplugged and cut off with out any dodgy running or what not. Thanks, Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 25, 2013 Share Posted September 25, 2013 Yes I removed mine completely and welded the resulting holes up, its actually the std traction control, you can also remove the ECU too. Quote Link to comment Share on other sites More sharing options...
jumpbike Posted September 26, 2013 Author Share Posted September 26, 2013 so the ecu that says throttle control on it is also no longer needed? The engines going in something else you see and it's going to be a squeeze so would like to shorten the throttle body, Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 26, 2013 Share Posted September 26, 2013 There is no ECU that says throttle control, it will have TRAC control on it, as I said its traction control, nothing to do with the throttle, which is cable operated. you should have no problems shortening the throttle body. Quote Link to comment Share on other sites More sharing options...
Scott Posted September 26, 2013 Share Posted September 26, 2013 Unless you have VVTi. Quote Link to comment Share on other sites More sharing options...
baldy Posted September 26, 2013 Share Posted September 26, 2013 It will affect gear shifting on an auto! Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 26, 2013 Share Posted September 26, 2013 How does the TRAC control have any effect on an auto box? also not sure how it would influence a a VVTI motor either? Quote Link to comment Share on other sites More sharing options...
Ian C Posted September 26, 2013 Share Posted September 26, 2013 Doesn't it use the TRAC butterly to help with gearchanges at WOT? I can't recall exactly, but I do seem to remember that the TRAC ECU does have something to do with the autobox... Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 26, 2013 Share Posted September 26, 2013 I'm not convinced just how it would be beneficial to close or partly close the TRAC butterfly during gear changes, surly this would lead to a more jerky effect like closing the throttle during manual changes but without a de clutch effect? especially given its reputation for being rather primitive in its operation during traction control operation. Quote Link to comment Share on other sites More sharing options...
baldy Posted September 26, 2013 Share Posted September 26, 2013 The flap does shut on wot gear shifting to smooth the shift and protect the box from a high load shift, unplug the motor and go try it!manu mode will not work with it removed either Quote Link to comment Share on other sites More sharing options...
Scott Posted September 26, 2013 Share Posted September 26, 2013 How does the TRAC control have any effect on an auto box? also not sure how it would influence a a VVTI motor either? I was meaning the "throttle control" ecu. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 26, 2013 Share Posted September 26, 2013 The flap does shut on wot gear shifting to smooth the shift and protect the box from a high load shift, unplug the motor and go try it!manu mode will not work with it removed either Glad I bought a Supra with a manual box then LOL! Especially after sampling the wonderful traction control while trying to quickly enter a busy roundabout and being momentarily stranded in front of a fast approaching truck, that was when I quickly discovered the location of the TRAC relay and binning it, shortly followed by the TRAC ECU, and later the throttle body was mullered. Quote Link to comment Share on other sites More sharing options...
Gpro Posted September 27, 2013 Share Posted September 27, 2013 I unplugged mine a few weeks ago so it stays open. I have noticed lightening speed gear changes since i done that. I just didn't realise it was because of that! Surely its a bonus!! the car feels like its just 1 gear from 0 to 100mph! you don't feel any of the gears changing its so smooth/Rapid changes Quote Link to comment Share on other sites More sharing options...
jumpbike Posted September 30, 2013 Author Share Posted September 30, 2013 I have noticed lightening speed gear changes since i done that. I just didn't realise it was because of that! Surely its a bonus!! the car feels like its just 1 gear from 0 to 100mph! you don't feel any of the gears changing its so smooth/Rapid changes this is what I wanted to hear, it will be running the standard auto in the other vehicle but if I can do away with the butterfly and the 2nd ECU then win win, won't immediately jib off the TRAC ecu incase it is liked to the auto box in any other way. Quote Link to comment Share on other sites More sharing options...
jumpbike Posted October 19, 2013 Author Share Posted October 19, 2013 There is no ECU that says throttle control, it will have TRAC control on it Just for reference, it 100% says Throttle Control on the second, smaller ECU Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 20, 2013 Share Posted October 20, 2013 If subjecting the auto box to sudden torque shocks above that the makers considered prudent is a "win win" situation, then out with the hacksaw The traction control butterfly does indeed operate during auto box gear shifts. Quote Link to comment Share on other sites More sharing options...
