Toad ai606 window closure and open
scott.wild
Hi, has anyone done this before? I am thinking a standard toad auto closure module will handle the closing and then using a second one connected to one of the other alarm outputs to handle total window opening. I am only interested in having the drivers side do this. The goal is to make it a little easier when getting in/out of tight spots. Also is it possible to have an automatic boot release from the alarm? Thanks
Hi, For the total closure you need a an extra module, toad PWC-402 or something similar that triggers from the white negative feed wire from your alarm. Wiring up is fairly straight forward although a little awkward. I chose to run a new positive fused cable from the battery which gives power for the module, from the module there are 4 wires which need to be fed to the drivers door window switch. It's then just a matter of cutting an existing wire that goes to the driver motor, solder each end of this to the pair of wires from the module, do the same for the passenger window. I did a dry fit first and did a few diagrams because i was adding a second module to handle driver window opening. Once it was all working tidy up the cables and solder and heat shrink all the wires. I have also added remote boot release now as well :)
