What would cause an ally connector to split?
Swampy442
I actually think it's just the corrosion. The fulmination effect produces pressure on the inside of the fitting and eventually cracks it open. You'll only get the crack where you have corrosion, not the other way around.
Could be both to be honest. Could be the fact the fittings at the wrong angle and has worn off the anodization where there has been pressure on it and has led to corrosion. Who's fitting is it btw? Earl's, Genuine Aeroquip?
Shouldn't happen with a quality fitting.
I've got an Aeroquip fitting under the car that goes into the fuel filter and it's done the same thing, having said that it is at an angle and exposed, and might be under more tension that perhaps I'd like, so cause and effect could be either way around. Happy to muddy the waters help :D
Many years ago I came down into the kitchen one morning and it was flooded with hot water. I had a flexi tap connector hose under my sink and that had failed in exactly the same way. Obviously concerned that the others in my house which were the same age and make were about to fail I removed them and they were all perfect and as good as the day they were fitted. For some reason it was only this one alloy connector that had fallen to pieces and I put it down to metal fatigue in the monkey metal used.
I should mention also that I didn't buy the flexis in the UK before someone says they aren't made of alloy, these were.
No idea mate, theres no markings so its a generic fitting. It maybe been on the car for 10 years and it was located in the wheel arch so Im going with the crack/corrosion idea :D
