girth45 Posted September 19, 2013 Share Posted September 19, 2013 Hi, can anybody help with info on fitting a boost controller, I have purchased pro 1 ebc controller, budget constraints and I like the way its a 52mm gauge, so neat and tidy, anyway have read instructions, OK with the wireing its how to attach it to the pipe work. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Hi anybody able to help with some advice on plumbing the boost controller in. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 19, 2013 Share Posted September 19, 2013 Try google for the instalation diagram Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 There are lots of thread containing boost controller install. Not trying to be rude, have to search sometimes. Here's a few link The plumbing are the same no matter what boost controller you have. http://www.mkivsupra.net/vbb/showthread.php?145933-install-boost-controller http://www.addictiveperformance.com/Images/hallman-toyota-supra-install.jpg http://www.97supraturbo.com/Pictures%20for%20Posting/%231%20Turbo%20EBC%20Hookup.jpg Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Do you not link both actuators to solenoid? Surely linking only one actuator will only control boost on one. - - - Updated - - - Do you not link both actuators to solenoid? Surely linking only one actuator will only control boost on one. Quote Link to comment Share on other sites More sharing options...
Gpro Posted September 19, 2013 Share Posted September 19, 2013 no you only connect it up to the actuator above the first turbo (Towards the front of the car) Connect turbo pressure (IN) connect to top of actuator (Out) Block off the port in the middle of the actuator Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 no you only connect it up to the actuator above the first turbo (Towards the front of the car) Connect turbo pressure (IN) connect to top of actuator (Out) Block off the port in the middle of the actuator Yes that Have a look on the pictures and you be fine. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 OK guys, thanks. But is that the optimal installation. I have read another article and that plumbs both actuators, it is on a 1jz engine in a mk 3. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 19, 2013 Share Posted September 19, 2013 Here you lazy so and so http://www.max-boost.co.uk/max-boost/supra/boosting_the_beast.htm Its not hard to find, if you actually read something you miht get a good idea on how to do it and understand it Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 (edited) And here's me thinking this was a forum for discussion and assistance, you are obviously arrogant and ill educated, you do not know me but make an assumption, if you have nothing good to say then say nothing! Edited September 19, 2013 by girth45 (see edit history) Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 The forum is for discussion and assistance, but sometimes it requires you to do your bit too You can imagine the amount of threads we get discussing the same topic, so it can be very repetitive. We are get along here but try and be nice or the mods will get you Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 What mellonman posted about the link is very good. It will give you a better understanding how the 2JZ works. Good luck with the install Quote Link to comment Share on other sites More sharing options...
listy Posted September 19, 2013 Share Posted September 19, 2013 Calm down kids Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 I had read the article previously, they talk of using two mechanically controllers, now to plumb into one turbo surly means only one is being controlled, there seems to be different ways of doing this all I was asking was which one is best and why, if you can't answer that then why be rude, you wouldn't say it to my face I assure you. - - - Updated - - - I had read the article previously, they talk of using two mechanically controllers, now to plumb into one turbo surly means only one is being controlled, there seems to be different ways of doing this all I was asking was which one is best and why, if you can't answer that then why be rude, you wouldn't say it to my face I assure you. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 Are you talking about Stuart Hagen's EBV mod? I personally have not tried it myself, but what I have posted with before about the install with links and etc. I am sure 99% of the members here who drives a BPU with a boost controller will be running with that set-up. Why not share the info you have on it with links and etc and maybe other members can share a light into this. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Yes it is a version of it, the article mellonhead linked to is a version of it, I am only asking the question, piping into turbo 1 obviously works as you say many have it this way , my question is it the best way, that was all. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted September 19, 2013 Share Posted September 19, 2013 I've got a SBC boost controller fitted to my car, I know it's not the same but if you want to have a nose under the bonnet you're more than welcome. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 SBC boost controller will probably be fitted just like any other boost controller, just like the links I have provided. About the Stuart Hagen's EBV mod. It really have nothing to do with the boost controller, he is bypassing or re-routing hoses to get more boost at low revs. If you are not sure, and you don't seen to fully understand yet. Play it safe and just fit the boost controller and adjust the boost to 1.1 to 1.2bars. Ignore Stuart Hagen's EBV mod and etc. One step at a time. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Cheers big in, will take you upon that, by the way, you followed me yesterday on Lawford road, car looking good, then you blasted past me, looks really good from rear, nice job. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Cheers dim sum. Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted September 19, 2013 Share Posted September 19, 2013 Cheers dim sum. You are welcome glad to have helped. We were all once newbie at this and its a learning curve. Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 19, 2013 Author Share Posted September 19, 2013 Just a shame some don't realise this, and prefer to be arrogant. Quote Link to comment Share on other sites More sharing options...
Big Mark Posted September 20, 2013 Share Posted September 20, 2013 Cheers big in, will take you upon that, by the way, you followed me yesterday on Lawford road, car looking good, then you blasted past me, looks really good from rear, nice job. I'm away tonight but should be back some time tomorrow afternoon so just give me a call and we can meet up. I think I've got it lookng just how I wanted now, got the new badges on and I changed the exhaust tip last month which has made a big difference to the look and sound but I need to get it up in the air later today as the exhaust is now knocking on something. Quote Link to comment Share on other sites More sharing options...
mellonman Posted September 20, 2013 Share Posted September 20, 2013 (edited) Yes it is a version of it, the article mellonhead linked to is a version of it, I am only asking the question, piping into turbo 1 obviously works as you say many have it this way , my question is it the best way, that was all. you sir are a cock just trying help as you asked for it , it did seem that you know nothing and that post is a very inforative read so you can do one lets test what this ingore button does , EDIT wow thats pritty impressive great feature Edited September 20, 2013 by mellonman (see edit history) Quote Link to comment Share on other sites More sharing options...
girth45 Posted September 20, 2013 Author Share Posted September 20, 2013 :idiot::idiot:Let's hope we meet one day. Mellonhead. Quote Link to comment Share on other sites More sharing options...
