Intermittant speedo fault
Benjy
Having had this auto TT for about 5 days, I've just noticed the speedo intermittantly messes about. I think it's after a bit of boostage, when you slow down and just trundle along, the speedo has a little bit of a spaz attack, jumps up a bit, drops off a bit, but then returns to normal.
Any ideas? Common thing? My thinking is it could only be speed sensor or clocks? Or possibly the conversion/delimiter chip?
Discuss.
It's usually a dodgy speed convertor, i'd start there. Could be a loose connection if it is when your boosting though.
That's the odd bit. It's not whilst on boost, but after. It dicks about for about 10 seconds then sorts its life out. I have got a spare converter/delimiter, so at some stage, when I get a chance to fart, I'll swap it over and see what happens.
  • 2 months later...
