Dazzi Posted September 17, 2013 Share Posted September 17, 2013 I've searched and even looked on the repair manual for an answer but can't find one. I'm looking to fit an additional transmission cooler to work with the stock radiator. There are 2 lines going into the radiator, which one is the pressure line and which is the return line if I'm stood facing the engine? Sorry in advance, my last supra was a manual Thanks Link to comment Share on other sites More sharing options...
2jzEd Posted September 17, 2013 Share Posted September 17, 2013 IIRC left line is pressure line. I Disconnected the hose on the right when i did my trans+cooler flush. Link to comment Share on other sites More sharing options...
Dazzi Posted September 18, 2013 Author Share Posted September 18, 2013 Thanks. So when you flush your transmission you disconnect the return line back to the box to flush out the cooler as well? Link to comment Share on other sites More sharing options...
2jzEd Posted September 19, 2013 Share Posted September 19, 2013 Correct. Link to comment Share on other sites More sharing options...
