No. 6 cylinder problem
FilS004
Hi all, looks like I still have a problem with my No. 6 cylinder. I have melted another plug in the same hole that the ground electrode burnt off earlier on in the year. All other cylinders are normal, so does anyone have any idea why this particular cylinder is melting my plugs?
Ok thanks again. It looks like I will be taking the head off for a proper look. I have blown my turbo's so i will be doing that at the same time.
What is the det?
Here is a link that will give you a basic explanation, http://www.contactmagazine.com/Issue54/EngineBasics.html
If you intend to modify/increase engine power you need to have a good read up on all the basics of engine tuning.
Yeah, already got a wide band lambda gauge Chris, but i haven't learnt how to read it properly yet. It idles at 21.5 and drops to 11 initially then moves up to 14ish while accelarating. I am also able to plug in to my laptop and look at a graph of what has been happening.
I will do the necessary with the 6th piston, because when I was looking with the bore scope, I saw a weird reflection from the lights that I thought was just a reflection of the lights in the oil, but now thinking about it, it could well have been a hole in the top of the piston. Bu**er !!
Head off then !
With regard to the flow test, my next stage was to upgrade the fuel system anyway.
Regarding the above 4, yes, idling at 21ish, initially 11 when I start to accelarte and it is around 14 whilst I am accelarting, definately. Can't reprove that, as it is not running now, but thast was correct. What does that tell you mellonman / Gpro?
Unless it was mapped when I first got it 13 yrs ago, then I don't know if has been mapped. It is a 93 TT
Yes, the last thread I fixed with new coil packs and new plugs.
I just read that other thread I even said det a year ago lol.
11 then going to 14 could be a failed sensor, did you buy the afr gauge new?
Just so you know 11. Means 11 parts air to 1 fuel, and 14 means 14 parts air to 1 fuel
So 11 is a rich fuel mixture and 14.7 is the normal idle / closed loop/, stoich ,mixture
15 or greater is lean
Driving should be 14.7 light throttle up to 0.5 boost
Accelerating building boost low13's
Full throttle should be low 11's
Lifting off throttle should be 18+
Hope that helps
No, I am not able to do anything on this until the weekend, as I have a poorly Jeep that really needs full attention at the mo, because my better half is driving my spare car, so I haven't got one.
I didn't know that the WBand required calibrating at any time, other than when I first put it in. I had to measure tha clean air just before I put it into the exhaust hole, so that it had something to measure. There was no mention of having to recalibrate in the instructions. It is a 'Innovate' wide band meter.
Innovate sensors need to be re calibrated under certain conditions, it does usually say in the instruction's, it can be done on closed throttle with the injectors shut off, I preferred to recalibrate mine every three to six months, better than the AEM chuck it in and forget it method IMO.
