TT Water leak
Cosworthmark02
Hi,
My car keeps leaking water from the header tank drain off pipe after a journey (can actually see the water coming out). The header tank when checked is then empty and the radiator runs a little bit low.
I've changed the radiator cap and can't see any obvious signs of a leak from the radiator or surrounding pipe work. There's no signs of head gasket problems and have had a recent compression test which showed very good compression.
On very hot days the temperature rises slightly above the centre on the temp gauge.
On a recent drive I used 2ltrs on the journey out and nothing on the return journey.
The radiator was replaced a few years ago.
I thinking of changing the radiator to an alloy version to start with, as this cars an auto how difficult is it to fit the transmission fluid cooler?
Cheers,
Mark.
  • 10 months later...
Guest Todorovac
Hi,
Cheers,
Mark.
Hi Cosworthmark02 - The car you owned was bought by a swedish guy and this car is now in sweden - he is working with japanease cars and importing alot of them , he now wants to sell it to me - im not sure if you are still active on this forum but i would love to get in touch with you and ask you some questions about the car since im thinking of buying it - i have found alot of info on the car on the internet , the single conversion and all that, i guess what i want to know is if its a good car that will not give me too much trouble? Whats the reason for you selling it ? With everything ive read about the car it makes me abit worried to buy it. Would appriciate your help alot!
