Octane boosters
pf85
Not 100% sure how they chemically work but I did read somewhere on a 'layman's terms' basis that octane booster will increase the effective RON value for 95RON or lower. (By how much is not really defined, but could be up to two points on older fuels).
On 97RON and above fuels the octane booster has nothing much to chemically 'bond' to in order the fuel RON value can be increased. So in effect as some have hinted it can actually have detrimental effects as this un-bonded addition in the fuel goes through the injectors and in to the combustion chamber.
I have heard of some people thinking that by adding 4 bottles instead of 1 believing that they are going to get 8 RON points higher in their fuel....doesn't work like that. If they are already using 99RON fuel they may well be reducing the RON value as they 'dilute' the fuel with un-bonded additives that don't by themselves provide any additional combustive effect over the internal energy of petrol.
To be sure about adding octane boosters to 97RON fuel on an engine mapped for 99RON fuel would probably have to be done on a dyno and computer. (Assuming the map is not able to compensate for differences in petrol fuel types and RON values).
Also, when they state "raises octane by two points", that's actually 0.2 RON. There's not enough in those tiny bottles to do much at all.
You're much better off mixing in 10% Toluene which you can buy from many chemical suppliers. If you tell them you're buying it for use as a fuel additive they'll sting you for tax though.
I stuck two bottles of octane booster in with £60 of 97 super and didn't see any difference except for a few flames out the exhaust , I actually noticed it hesitated a little on full throttle, either that or my coil packs are starting to die :)
97 runs perfect
95 isn't great but only used for emergency get me home if no super is to be found
