Poshmalc Posted September 15, 2013 Share Posted September 15, 2013 What is this that has been blanked of guys and why is it pissing oil everywhere? Any way I can fix this? Cheers in advance, Matt Quote Link to comment Share on other sites More sharing options...
ScottC Posted September 15, 2013 Share Posted September 15, 2013 It's blanked off because you're bov is venting to atmosphere. Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted September 15, 2013 Author Share Posted September 15, 2013 I thought as much, Why's there so much oil leaking though bud? Quote Link to comment Share on other sites More sharing options...
hodge Posted September 15, 2013 Share Posted September 15, 2013 It's leaking oil cos your turbo oil seals are on there way out. Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted September 15, 2013 Author Share Posted September 15, 2013 Oh crap, that's going to be expensive! Quote Link to comment Share on other sites More sharing options...
skippyboyo1 Posted September 15, 2013 Share Posted September 15, 2013 Yup oil seals. Smile and get it fixed. Simples Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 15, 2013 Share Posted September 15, 2013 that could be a build up over time mine has abit that comes out,but has been like it for a yr oil etc is fine, check oil level wipe it clean drive it for say a wk see how bad it is then you do get some oil in the pipes and recheck oil level Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 15, 2013 Share Posted September 15, 2013 Its just a build up of oil fella, don't panic, its quite normal, you have the std PCV system still running so any oil vapor from the engine gets fed back into the intake just before the turbo and also the plenum so the BOV will throw out a little oil mist. Quote Link to comment Share on other sites More sharing options...
hodge Posted September 15, 2013 Share Posted September 15, 2013 He did say it was pissing oil everywhere. Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted September 15, 2013 Share Posted September 15, 2013 (edited) True but the pic doesn't exactly look like its pissing oil to me, mine was exactly the same wen I bought it, and after a quick clean it took three months to look the same, my turbos where fine, the 2JZ will dump some oil from the BOV because of the stock PCV system. Edited September 15, 2013 by Tricky-Ricky (see edit history) Quote Link to comment Share on other sites More sharing options...
Guigsy Posted September 16, 2013 Share Posted September 16, 2013 Its just a build up of oil fella, don't panic, its quite normal, you have the std PCV system still running so any oil vapor from the engine gets fed back into the intake just before the turbo and also the plenum so the BOV will throw out a little oil mist. This. I had it. Wiped it away. Never came back Wipe it off and see how quick it comes back if at all Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted September 17, 2013 Author Share Posted September 17, 2013 Cheers for the great advice guys, okay so pissing may have been a tad harsh, but I've now cleaned it up and I'll keep an eye on it over the coming weeks/months Matt Quote Link to comment Share on other sites More sharing options...
Thorin Posted September 18, 2013 Share Posted September 18, 2013 Check the inside of your air intake, if there's a bit of oil residue I wouldn't worry. If it's dripping out, it's new turbo's time. Quote Link to comment Share on other sites More sharing options...
Poshmalc Posted September 18, 2013 Author Share Posted September 18, 2013 There was just a little residue, hopefully for now then they'll be okay! No smoke on boost at all, so I'm not hugely concerned! Quote Link to comment Share on other sites More sharing options...
TT Paul Posted September 18, 2013 Share Posted September 18, 2013 There was just a little residue, hopefully for now then they'll be okay! No smoke on boost at all, so I'm not hugely concerned! just monitor it check oil level and should be good Quote Link to comment Share on other sites More sharing options...
